Garden Decking
Im thinking of doing some decking in my garden, just wondered if anyone on here has done it them selfs
If so how easy/hard was it
any tips
and whats the cost like, i gunna do about 3 mtrs x 4.5 mtrs
Thanks very much for any help
any tips
its what i do for a living mate. easy mate . just prepare well and think ever thing through be for cutting etc.
roughly be about Ł300-Ł350 depending on fixings and where you get the wood . wickes is cheap but crap wood in my opinion . shrinks and moves alot . not cut that well either . some where like a BuildBase is half decent . 4x2 is fine for the frame if supported well .
where abouts are you based mate ..... mite be able to sort you out
this was the basic frame before i put legs to support it
this was after
this was one in a school pond
after i clad it
basically if i was doing yours id make a frame that was slightly smaller than the wanted area, then space the rafters at 18" centres , then you lad the other way . if you cant get one piece of decking all the way across and have to join . then mirror the join as if you were doing a laminate floor , if you get my drift. just pm me if you get stuck
this was after
after i clad it
thanks for your help mate, im in kent
Im looking at it and dont think it will be to much hassle,
heres where im thinking of doing it
as i say its about 3000 out from the house and 4400 across
was thinking to run the decking planks across so would i gat a 4.4mtr plank
most boards are 3.6m , 4.2m and 4.8m. you could get 4.2m boards and leave a 100mm gap each side of the deck and fill white coloured shingle etc ?? saves buying 4.8 and wasting the off cuts plus the edges will look like a nice feature
Howarth timber do deck boards up to 5.2m iirc so your ok with width.
Remember that its whats beneath that counts. Make it strong. You dont want it sinking when you have a big party. Or, are you planning on a hot tub? Some weight there! All things to consider.
We never just stake decking. It is always sat on concrete pads......no matter how high.
i'm looking at a 3x3.75m area. obviously wooden posts sank in a decent way with contrete couple of decorative posts with rope estimating about 300-400 that sound reasonable? then i gott dig a soakaway and turf the garden
I have been quoted 2500 for an area 6.5m x 4m, ground slopes down around 1 foot.
This included lights in the decking floor, double handrail covering 10m? turned spindles and one step.
That sound right?
That sound right?
I've just did mine. Done it all myself, best thing you can buy it a decent mitre saw, saved me god knows how long. Will put pics up in a min when I get them on photobucket.
As long as preperation is good, boards should go down no problem.
SMG
SMG
That sound right?
That sound right?
like new flashy trucks like "warriors" and "navara's" or my bosses Ł27,000 Animal !
Heres my effort!!
When we moved into this house we had to dismantle an existing conservatory as it was too close to the boundary and didn't have a fire retardant wall. I was going to take out one side and brick it up but the thing was best part of 15 years old and was showing it's age so we just took it down. Until we get a new one (after the wedding) I decided just to deck the area and re ruffcast the wall. as it was in a bit of a mess after taking the conservatory down.
Anyway here are pics, got some blue LED uplighters and put them in as well.
Pictures were taken after some rain so don't really do it justice. but you get the picture.
I've still to put on handrails and build a step.
SMG
SMG
matts1
sounds right to me, but as woodz says it does vary a lot, as a lot of companies are setting up as decking specialists, like its some sort of art when in reality its basic joinery.
Keith the deck boards we use are 110mm in width and 30mm thick.
We lay with a 5mm gap between.
Originally Posted by xr3-keith
good stuff
get them pics up please
have just done a search and found that there are loads of different width boards
what screws would anyone suggest
you want some decent ones with a Torque head (T25) better than the usual cross head ones . you can put these in and out loads and they are still good . Ł12-Ł15 a box of 250 but if you buy cheap ones you will be swearing a lot at findgnf 40ish of them with crap , blocked heads and then them shearing etc. Do it right and do it once
good stuff
you do want to leave a littl gap due to the wood expanding and shrinking . butt it all up and you mite get rising boards etc also some of the boards you get mite not be 100% straight and you will be fighting them to bend them straight to butt them up and then straight away your are putting a strain on the board and it will be wanting to move if you know what i mean.
I just used the screws that the timber supplier gave me. never wasted one all went in no problem. Had a square hole on the head of the screw and got a wee drill bit free in box.
Smiggy
Very nice mate, how much did the mattierals come to if you dont mind me asking
woodz77
Liking the sound of t25 mate
have now worked out the timbers i need for the frame
so far i got
3of 50x100x4400
11of 50x100x3000
2 of 6ft posts
? bags of post mix
? deck boards
screws
wall fixinings
how that look
Thanks for all the help and advice so far
woodz77
so far i got
3of 50x100x4400
11of 50x100x3000
2 of 6ft posts
? bags of post mix
? deck boards
screws
wall fixinings
how that look
i think the boards we use are 120mm wide and as a rough guess its 8 boards to a meter to id guess 24 and then 1 for the front to cover the frame .
as for fixing to the house theres always any arguement weather it creates problems with damp and water traps against the house . but its up to you . it give a perfect and strong fixing
to fix to the wall i would use a thing called a magic nail or better known as "express nail". best thing ive ever come across. you drill a 8mm hole through the wood and then into the wall 2.5 inchs. then hammer the magic nail through the wood and into the wall . they are 4" long so 2" sits in the 2" wood frame against the wall and the other 2" sits in the wall . believe me , they dont come out . no screwing or lining up rawplugs, just hammer in and then as if by magic it grips like a nothing else !
i will get a pic 2moro of one . if you fancy them pm me and i could post you a couple
Smiggy
The uplighters were extra, got them from CEF at a discount as well knew a guy who worked there. They worked out just over Ł20 each. Normally retail at Ł22 for the fixing and about Ł7.50 for the LED bulb. I bought 7 so saved a wee bit.
Also bought a Mitre Saw from B&Q in their 1/3 off sale. Picked that up for about Ł64 and now that I'm done with it I'll sell it on. Would seriously recommend getting your hands on one of these as it saves ages of time and also I got all my angles spot on.
