quick one.. i think.
Old Jun 9, 2007 | 01:04 PM
R5FORD's Avatar
R5FORD
Default quick one.. i think.
ok peepz..
i have a 2wd saph on stage 1 atm, in couple weeks its going to get closed loop, which requires a 4x4 ecu, but at the same time its going to get stage 3 treatment..what do i actuly need for stage 3, as im a lil confused, as my cars 2wd will i still need all the 2wd equipment or 4x4 equipment because of the ecu?
cheers
Old Jun 9, 2007 | 01:36 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
803 (dark green) injectors,3bar map sensor,(good condition actuator) -31 i think u'll need a 4x4 tps sensor if ur going l8 and seeing as ur in a hot climate i would get a decent 500 style cooler.....
Old Jun 9, 2007 | 01:38 PM
R5FORD's Avatar
R5FORD
iv got a 500 cooler, getting a t34 turbo, greens, 3 bar sensor, i have a -31 actuator,
so will i need a 4x4 chip and board?
Old Jun 9, 2007 | 02:30 PM
pete mcrash
if ur getting the stuff from msd just ask stu.............one thing i would say,is i wouldn't ever use greens with a t34 again.....i would go bigger to be on the safer side........ur cloosed loop "chip" will be ur new "chip", u will still need a 4x4 throttel position sensor and some way of checking u've fitted it right.....
Old Jun 9, 2007 | 02:48 PM
R5FORD's Avatar
R5FORD
what happend mate witht he greens? iv been told that it should be ok, as its a t34 with .48 housing
Old Jun 9, 2007 | 03:02 PM
Alvyn's Avatar
Alvyn
as long as it's ALL set up correctly 803's WILL be fine with the turbo your going to use!
only 4x4 bits needed for you are the l8 ecu,chip and board and as said above the tps sensor but DONT forget to switch the 2 outer wires that go to it also.
Old Jun 9, 2007 | 11:35 PM
R5FORD's Avatar
R5FORD
so the chip from stu ( closed loop) is that going to be the power chip aswel?
or is the closed loop chip diffrent to the say 330 bhp chip?
Old Jun 10, 2007 | 08:15 AM
CharlieSaff's Avatar
CharlieSaff
Your new power chip i.e stage 3 to runs greens etc is the one you're getting from Stu, and that has closed loop built into that same chip aswell
As said if going L8 get a 4x4 TPS and switch the wires round
Old Jun 10, 2007 | 12:02 PM
R5FORD's Avatar
R5FORD
hey thats good news..i though i would be spending 300 with stu and then 300 for a stage 3 chip and board..
thanks for the info..
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
