Amal Valve Jets
Amal Valve Jets
Anyone know what size to drill the jets out on an 4x4 cossie AMAL valve to get more boost. -34 actuator and standard 4x4 t3. Its having a re-map at the same time, I just need to know which jets and what size
Hugh
Hugh
I think you can replace them but as I don't have any of the correct size, drilling them is my only option at this point, seeing as its getting re-mapped at 10am for full throttle gearchanges, and more bost
saff is working!!!...atm
ur "remapper" will do all that shit for u!!!!...unless he's a dimwhit,then ur better off to B&Q and asking in store.............. ....why on earth are u using a -34 on a t3?????
Originally Posted by pete mcrash
ur "remapper" will do all that shit for u!!!!... ....why on earth are u using a -34 on a t3?????
and 34 on t3 -34 is for boost over 30psi
your turbo will last fuc all miles !!
PassionFords Creator
-34 will be fine on that turbo with the amal correctly jetted. A -31 with a full whole preload is about the same strength.
Your mapper should know how to rejet the amal mate, just leave it to him.
However, if your keen to mess:
To increase the held reading, increase the bleed size of the "R" port.
To increase the peak, Decrease the bleed size of the "C" port.
To Increase both, decrease the size of the "W" port
focus rs 1672
cheers
Originally Posted by JamboRST
stu would this work for an erst amal valve too,im havin troubles with not holdin boost high up,ive got the 'C' port bleeder decreased and it peaks at 21psi but by 6k rpm its down to 16.3psi,could i use this to get more boost held top end or does it only apply to cossies
cheers
cheers
Once the engine starts to consume all the air you can give, the restriction starts to fall and thus so does the pressure in the inlet. It doesnt mean you are flowing less air, only that your compressor is struggling more than it did earlier when the engine efficiency and speed was a little lower.
You do of course consume almost double the amount of air at 6000rpm as you did at 300rpm, hence its easier to get the boost higher, lower in teh rev range.
If that makes sense? lol
focus rs 1672
yes it makes sense mate,alan at ava reckons its my intercooler(grs twin pass),theres plenty fuel top end as we've had the boost at 18-19psi at 6k but the mid range then is around 24-25psi which is too high for the prehistoric k jet to keep up and your getting cracks of det,so had to get turned back down to a safe level but only 16.3 at 6k
what size jet for the 'W' port?
cheers
cheers
