Adjustable rear trailing arms
What are peoples thoughts on making the cossie rear arms adjustable using rose joints etc? There is a company near me that modifies the trailing ams, and makes them fully adjustable. Obviously they bont modify the beam to make it a 6 degree one, just wondering if this is worth doing for about £300? can you get enough adjustment to get rid of the toe and camber issues or is it the beam that causes the problems in the first place?
why don't you elongate the holes on the inner mounts and weld washers on to hold in place? save you a bit of money.
also I think its the wishbone location on the beam and the length of the inner arm that causes the problem.
might be wrong though.
will you tight cunt !!!!!!!!!!!!!!!!!!
£550 you have the proper thing modifying the standard beam can not be made to suit as it needs to be alot further forward
rember how my saff went around corners and get ya cash out
my escort will be running around 420+bhp, Can you use a 7.5" 2wd diff on the back? , as I was thinking about gettting the beam first , made to take a 7.5" diff,but keeping the 7" diff and using spacers until it pops, then throwing a decent diff in ... is this possible?
I also need a beam for a 4x4 saff cossie that has been converted to 2wd, and I want a 10.5" jag diff in it
didn't realise your road beams were so cheap , how much is a strapped one?
Can't remember if you have to run coilovers as well?
you pair tight cooonts
i can not do them any cheaper these are exchange aswell
if you want to do loads track days then yes a strapped beam is what you need there are £675 now due to price increase in bits i need
jag diff beam is £900 or £1050 if you want tubular
ring me tonight we av a chat
you dont get bushes for the beam its up to you poli or ally up to you
the trailing arms are adjustable same pick up points on all the beams just diffent levels of strength in trailing arms
Tony W
09-09-2015 12:08 PM
