anyone here know anything about combi boilers ?
right, our boiler keeps lighting for say about a min and a half every 25 mins or so even though we have the central heating and hot water turned off all the time ????
should it be lighting up all the time like this ?
how do we stop the fooker ?
matt
matt
tis weird because we have a emertion tank also, whenever you turn the hot water on for shower etc theres hot water from this tank but the boiler doesnt come on lol
Matt
Matt
Would say you have a system boiler linked to a thermal store by the descripion you give not a combi, if this is the case the boiler is firing to maintain to store temp.
But with no demand water/heating it sould not fire so often,maybe the control stat is starting to fail and is cycling in out
its all only just over a year old
boiler is a fernox classic se15 ff
underneath that on the wall is a siemens rwb29 control unit but everythings set to off on that
matt
matt
jon, yes it does say ideal on the casing but i would say far from that lol
so there is deffo something wrong somewhere ?
whats the little knob on the boiler control panel for numbered 1 to 6 ? it was on number 6 for the first month but ive just turned it down to 1 thi afternoon from number 3
matt
matt
Hi Matt thats a Boiler thermostat 1 lowest to 6 highest
If you turn HW+CH to off but turn the Boiler stat to 6, and see if the boiler comes on more frequent?
an ideal classic is NOT a combi boiler.
There wil be an end switch stuck on a zone valve...
Cut the power to the boiler to sort in meantime and get a gas eng out to fix it.
I would deffo say you have a timeclock/wiring problem, if it hasnt always done it(since you had the boiler fitted) it could be that the timeclock has gone to open circuit
BTW whats a end switch and a zone valve ?
also all radiators that can be turned off are turned off, there is a temp control downstairs in the hall aswell ?
that set to about 15 degrees if i remember
matt
matt
Originally Posted by slowpoke
so something is fooked then
hopefully because we are renting we should get it sorted F.O.C then ?
matt
matt
coRdiS
13-03-2005 09:05 PM
Christian and Beccy
53
22-01-2005 07:06 AM
Christian and Beccy
13
18-10-2004 04:53 PM
