Bigger rads...
Bigger rads...
right im fed up of my rst's overheating ive had it with them doing it! now i plan to find the problem with my car and fix the bugga, but what options do i ahve for keeping it cooler?
what options are there for bigger rads on erst's? i know there are pace full length etc but thats no good because i run a chargecooler where the original i/c would fit.
so can you get rads the same size that are proven to be more efficient? maybe thicker cores etc
would just like to do a bit of preventitive work instead of fixing the buggas for once.
Originally Posted by James_FRST
so none of you run erst with bigger/thicker/more effieint rads?
I personally would recommend using too thicker core.
sounds better than the ford 1, how much does the most efficeint rad you stack in standard width and height cost graham?
