esc cos technical
Old Sep 21, 2004 | 04:44 PM
bbigman2000's Avatar
bbigman2000
Default esc cos technical
gents ive been having a real bad idle, hunting up and down, running real crap
now I pulled the hose of the inlet manifold the one that goes to the map sensor and instantly it starts running perfect ?
what is that indicating please ?
Thanks Glen
Old Sep 21, 2004 | 04:46 PM
Spiky's Avatar
Spiky
ISCV, take out and clean with carb cleaner
Old Sep 21, 2004 | 04:51 PM
bbigman2000
done that mate and also bought a new one tried that no change
Old Sep 21, 2004 | 04:57 PM
Spiky's Avatar
Spiky
the blue water temperature sensor or TPS
Old Sep 21, 2004 | 04:59 PM
bbigman2000
have got a new blue temp sensor here mate, will get that in asap, the TPS was working perfect prior to fitting my new motor, im strugglin with this one
Old Sep 21, 2004 | 06:15 PM
bbigman2000
anyone help ?
Old Sep 21, 2004 | 08:04 PM
Dave Henshall's Avatar
Dave Henshall
hmmm, it is a 3 bar map sensor isn't it, and not the std escos 2.5 bar one... if the chip is expecting to see x.x volts at idle and is actually getting y.x volts until you take the pipe off and then it just happens to read x.x by fluke, ?
has it got a vent to atmosphere dump valve?
Old Sep 21, 2004 | 08:34 PM
bbigman2000
hi dave yes its a stage 3, with 3 bar map sensor
and it does have a VTA ?
cheers for the assistance again
Old Sep 22, 2004 | 07:46 AM
Dave Henshall
just try diconecting the vac line off the top of the DV, and put a small bolt in the end ot the pipe to block it, see if that stabalises the idle....
`spotty
Sep 25, 2015 11:41 PM
coscor86
Sep 20, 2015 01:21 PM
Sep 18, 2015 02:27 PM
BigD.
Alloy wheels and ICE for sale
Sep 16, 2015 03:08 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
