Stupid oil question :cry:
what tempertaure does oil get to under normal driving conditions and how long does it take to get there?
I just connected all my Defi guages and the oil temp one didn't move from 50degrees in a 10 minute journey. Just wondering if it would take longer to heat up or if i have f***ed up the wireing
cheers
Paul
cheers
Paul
You'll need longer than 10 minutes to get it warm, depends on the temperature outside, will take about 10 MILES until the oil is at 70-80 degrees, this is when you can safely rag it, ragging before damages your engine nicely
My deffi doesn't move for about 10 mins either mate as the oil takes a while to warm-up hence not giving the car any stick for a good 5 miles or so! Normally reads around 80-90 after that
main thing is to ensure that the sensor is exposed to oil 'flow' at a representative temperature. In the sump is fine.
Mounting the sensor, for example, in a 'dead end' fitting off the side of the crankcase oil pressure adaptor, is likely to not give a representative temperature of the bulk oil.
oh it did go up on the way home racing....ummmm i mean following a coupe 20VT
i thought my sensor was broken lol
cheers for the replies people
Paul
andrewmctiernan
08-09-2015 03:05 PM
Adam Graham
06-09-2015 06:04 AM
