what would happen if (efi question)
Old 31-05-2007, 09:42 PM
jonesymk2
jonesymk2's Avatar
Default what would happen if (efi question)
what would happen if you unplug the tps,co pot and disconnect the pipe 4 the map sensor from the inlet manifold,would the engine still run and rev up
what would happen if you unplug the tps,co pot and the iscv but hold the revs up a little so the engine doesnt cut out,would the engine still rev up
Old 31-05-2007, 10:06 PM
jonesymk2
jonesymk2's Avatar
any body
Old 31-05-2007, 10:37 PM
jayRS
jayRS's Avatar
it would cut out, if it didnt, it wouldnt rev very well (if at all) and run like a bag of dog shit
Old 31-05-2007, 11:18 PM
Billy_RS
Billy_RS's Avatar
Old 01-06-2007, 12:33 AM
jonesymk2
jonesymk2's Avatar
thats what i thought should happen but it doesnt seem 2 make any difference atall
Old 01-06-2007, 12:34 AM
jonesymk2
jonesymk2's Avatar
Originally Posted by Billy_RST
what u laughing at
Old 01-06-2007, 09:22 AM
jayRS
jayRS's Avatar
WTF, does the fuel pump prime all the time when only the ignitions on? all i can think is the ecu is in limp home mode
Old 01-06-2007, 09:30 AM
jonesymk2
jonesymk2's Avatar
when the ignition is on it primes then when u start the engine the pump starts pumping the fuel as normal
Old 01-06-2007, 09:56 AM
jayRS
jayRS's Avatar
so it buzzez then stops, start car and away you go then.
beats me mate, with all them sensors disconnected it should run like shit or not at all
Old 01-06-2007, 10:00 AM
Billy_RS
Billy_RS's Avatar
bttt
Old 01-06-2007, 10:15 AM
jonesymk2
jonesymk2's Avatar
yep buzzes then stops,then fire car up and it runs and the pump buzzes away pumping the fuel
Old 01-06-2007, 10:40 AM
jonesymk2
jonesymk2's Avatar
just tried sumthing else i unplugged the co pot,tps,iscv and the pipe from the inlet manifold 2 the map sensor then tried starting the car,it was a pig 2 start but it started then it wud also rev up aswell
Old 01-06-2007, 10:44 AM
vroomtshh
vroomtshh's Avatar
If you really want it to break, just chuck some metal filings in with the oil. Much simpler
Old 01-06-2007, 10:51 AM
jonesymk2
jonesymk2's Avatar
well at the moment im trying 2 figure out whats wrong with it and if theres any problems with the sensors so was hoping if i unplugged them 1 by 1 it might highlight a problem but it takes the piss when all of those sensors are unplugged and it still starts up and will rev up,obviously i didnt rev it 2 much or leave it running 4 2 long either
Old 01-06-2007, 11:00 AM
xr4x4rs
xr4x4rs's Avatar
what problems are you having
would if been an easier question than asking what if i disconnect all my sensors would i be able to rev the engine up
Old 01-06-2007, 11:06 AM
jonesymk2
jonesymk2's Avatar
well i hav asked questions a few times b4 and never got anywhere really
Old 01-06-2007, 11:10 AM
xr4x4rs
xr4x4rs's Avatar
it would be a lot easier though mate
as you dont know what damage you can cause by disconnecting the sensors and trying to hold it on revs
Old 01-06-2007, 11:16 AM
jonesymk2
jonesymk2's Avatar
yeh i know mate but every time ive asked a question i either dont get any replies or hardly any,then when i do get replies they dont seem 2 make any difference,ive asked questions about the co pot cause that doesnt actually seem 2 do anything and there is voltage going into the sensor through 2 of the 3 wires,then when i thought i was onto sumthing sum1 else said sumthing else which made the 1st lot of advice void basically
Old 01-06-2007, 11:30 AM
xr4x4rs
xr4x4rs's Avatar
whats the actual problem?
Old 01-06-2007, 12:52 PM
JohnnyB
JohnnyB's Avatar
a EFI car will run if one or the other is connected
it has to have some way of quessing the gass flow into the engine.
but not if all are discontected.
but say if one or two leaking injectors it may try and run.
Old 01-06-2007, 05:24 PM
jonesymk2
jonesymk2's Avatar
well when its ticking over its running very rich whether its got blue or beige injectors in or if the chip is plugged in or not,it will rev up but sounds like it misses a bit but will rev past it,then when i try 2 drive it as soon as it starts 2 come on boost it starts 2 cough and splutter and impossible 2 drive but as soon as u dip the clutch it will rev up until it gets loaded up again when i lift the clutch,the co pot doesnt seem 2 make any difference when its adjusted either way so i thought it might b that but sum1 said its not,it might just need setting up but i didnt want 2 take it 4 a setup and there b a problem that i havnt noticed
Old 01-06-2007, 05:29 PM
xr4x4rs
xr4x4rs's Avatar
have you tried a different map sensor?
and do they have a water sensor for the ecu
i carnt remember
Old 01-06-2007, 05:37 PM
jonesymk2
jonesymk2's Avatar
well ive had it running with all those sensors disconnected at the same time
how tight should the injectors be then,wud u b able 2 turn them in the pockets when the fuel rail is on aswell,how low should the injectors sit in the pockets in the inlet manifold
Old 01-06-2007, 05:41 PM
jonesymk2
jonesymk2's Avatar
i carnt remember
i havnt got another map sensor 2 try i had enough trouble finding the ofac 1 ive got now,where wud the water sensor b located wud that b the sensor in the inlet manifold underneath
Old 01-06-2007, 05:55 PM
xr4x4rs
xr4x4rs's Avatar
yes
should be a blue sensor 2 pin connector
as if this has failed then it will tell the ecu to put more fuel in as its thinks the engines cold
i take it your running ofac ecu aswell and you have defintly got a ofac map sensor not a xr2i or xr3i one as they look all the same bar the part numbers
Old 01-06-2007, 09:36 PM
jayRS
jayRS's Avatar
sounds to me like the fuel pump is on its way out and not giving enough pressure, my rs done the same when the fuel pump started going wrong.
it also ran like shit once when the cam ate the ass off a tappet
Old 01-06-2007, 11:27 PM
jonesymk2
jonesymk2's Avatar
yes
yeh def got ofac map sensor,i will try the water sensor aswell,like i said it might just need a decent setup but i wud prefer 2 get it running better than it is b4 the setup so i dont hav 2 fork out twice 4 another setup if the 1st setup shows up sumthing silly
Old 01-06-2007, 11:28 PM
jonesymk2
jonesymk2's Avatar
surely if the fuel pump was at fault it wouldnt run rich all the time
Old 01-06-2007, 11:36 PM
jayRS
jayRS's Avatar
no prob not, but you have said you have tried everything else so maybe test something you havent.
Old 01-06-2007, 11:40 PM
jonesymk2
jonesymk2's Avatar
ok then i will try that but how can i check it
Old 01-06-2007, 11:58 PM
jayRS
jayRS's Avatar
fuel pressure gauge, you can buy a kit, or just nip down a tuners/garage and get it checked.
ive re-read the problem (you posted) are you sure all 4 are firing? what are the plugs like, are any HT leads damaged or broken, and have you had any plugs off.
also has anyone adjusted the co adjuster or the fuel pressure regulator
Old 02-06-2007, 12:17 AM
jonesymk2
jonesymk2's Avatar
all 4 plugs were new and all 4 leads were new aswell,also replaced the coil pack aswell,the fuel pressure regulator still had the cap on so hadnt been adjusted,i removed the cap and if i adjust it it makes a little bit of difference,the co pot didnt hav the cap on it so cud hav been adjusted but if i adjust it it doesnt make any difference atall
Old 02-06-2007, 12:18 AM
jonesymk2
jonesymk2's Avatar
basically no matter what ive tried nothing makes any difference atall
Old 02-06-2007, 12:26 AM
jayRS
jayRS's Avatar
the co sensor wont have a cap, and tbh adjusting it makes little differecne but can make you get more fuel, i had mine adjusted when at power engineering, didnt notice any difference but he said it would, but who knows lol.
if all sensors seem to work, fuel systems ok, ecu is fine, basicly your saying everything apart from the engine it self is ok, so now you have to look at the fact that something within the head could be naffed.
my rs ran like shit for a while once, i went through everything, then finaly came to the fact that something in the head must be to blaim.
it was, this
on the left is a good tappet, on the right, one that got eaten by the cam, thanks to this the swarf fucked the big end below and i had to rebuild the engine, the cam was scrap to as it wore the cam out
Old 02-06-2007, 09:21 AM
jonesymk2
jonesymk2's Avatar
surely if there was a problem with the head it wud show all the time wudnt it,it only seems 2 play up when the engine is under load when the turbo starts 2 spool up
Old 02-06-2007, 09:32 AM
jayRS
jayRS's Avatar
yeah, but your telling me everything else is fine, so i got no other ideas other than the engine or its associated parts.
if you really belive its not the engine your have to start again as something isnt right.
thats the thing with problems like this, you cant give too much of a accurate answer without seeing the car, mo so if your saying everything is ok and the car still runs like shit
your gunna have to get it somewhere and have it tested on a machine, i still stick with what i said first, a sensor has gone down, and remember, unplugging a fucked sensor wont make any difference to the way it runs as its fucked and the cars running back before you unplug it.
sorry mate, i can see why people havent been replying to your posts, they prob dont know the problem as you have said everything is fine, and its now got to the point you have to take it somewhere to be sorted, we/i cant say what is at fault if you maintain everything is ok.
the 4 most impornat sensors (not including the MAP sensor) ar the water temp back of inlet, ACT at top of inlet, the TPS, and the speed sensor off the gearbox.
other than that, take the ISCVoff and clean it, it prob wont make a difference but its prob due for a clean and wont do ay harm
Old 02-06-2007, 09:47 AM
jonesymk2
jonesymk2's Avatar
ok then cheers mate will try that,i will try the water sensor aswell
Old 02-06-2007, 09:49 AM
jonesymk2
jonesymk2's Avatar
i just cant understand y the car still runs almost the same when all those sensors are unplugged but nevermind
Old 02-06-2007, 04:45 PM
jayRS
jayRS's Avatar
it runs the same as its not running spot on, as something is not right, so its reverted back to a "safe" if you want standard programe, so unplugging things wont always sort it.
if for agrument sake the water sensor was at fault and you fitted a new one and it started running fine, and you unpluged something differnt you would then see a change, the fact somethings "chanegd" already unplugging more stuff insn;t highlighing the problem.
if you cant get it on a machine to test the ecu for fault codes your have to do it the hard (and sometimes expensive) way and replace the sensors 1 by one, fitting new or 100% fully known to work s/h ones
Old 06-06-2007, 11:36 PM
jayRS
jayRS's Avatar
sorted it yet?
Quick Reply: what would happen if (efi question)
