Msd closed loop chips co question
Testing the future
why would you try and set something that is trying to be controlled in a closed loop?
i think that you need to set what is commonly called the "CO pot" to it's central position as that sets a multiplier for the entire fuel map, and then the closed loop control takes care of the idle mixture to give the correct emmissions (CO etc)
as long as the emissions tester is reading 0.7% CO at idle and the engine is sufficiently warm that seems fine
can i assume its the MSD closed loop?
mine runs at approx 0.6%CO at idle
chowfornow
14
05-01-2019 09:01 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
