Best way to secure a CV gaitor
1 of my inner cv gaitors keeps popping off and its really getting on my tits.
its only just started to happen since ive used the car this year, last year it was fine. i have fitted a 3inch bore exhaust system and it is abit closer to the same gaitor but not too bad, its the only thing ive changed
ive tried using normal cable ties but it didnt work, then i tried an extra chunky cable tie and even the metal type but they still dont work. what else can i use cos i dont really want to change the gaitor if i dont have too
Originally Posted by xr4x4rs
did you clean the inside of the gaitor first mate where the clip would go round?
if not then you wont get a tight fit due to the grease slipping it off
the metal straps thats used on them should hold up very well though
you could try a jubilee clip then
if not i dont know what else to suggest
wont it unbalance it
I used a jubilee clip on the driveshaft of a mondy auto 4 years ago and perfectly ok, can't feel a thing, the amount they weigh compared to a driveshaft is nothing to worry about.
