zetec no spark
23-05-2007, 10:17 PM
Back in black!
zetec no spark
just got an escort 1.6 si zetec and it has a intrmittent fault
it will spark 2/3 times and then nothing its got a new crank sensor and
coil pack at best it ran for about 10secs and then nothing
is there any thing i am missing???????
23-05-2007, 10:46 PM
plugs, leads, fault with the ecu???
just throwin ideas about
24-05-2007, 06:28 AM
Back in black!
checked the plugs and leads came with coil pack
will try another ecu (if i can find one)
24-05-2007, 02:49 PM
could the fuel pump not be workin properly??
or is it defo summit to do with the ignition?
24-05-2007, 02:51 PM
Team HOTHOT!
Try the middle wire on the coilpack - make sure that there is 12 volts getting to this when the ignition is on. I had the same problem a couple of years ago on one of the early edis cvh escorts
24-05-2007, 04:59 PM
Back in black!
deff ignition
24-05-2007, 09:23 PM
Back in black!
sorted all it was was a loose connection at the ecu
25-05-2007, 12:45 AM
brill, well done for tracking it down and glad it was something simple
25-05-2007, 01:03 AM
Mine uasuly does 3 clicks then goes out when cold, and i know the reason.
the battrey, check your battreys ok first mate, as there a basterd at times
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
mondeomark
28-09-2015 06:28 AM
