were can i get a 90degree bend pip like areoquip etc
need one thats going to come out off my rocker for breather pipe so it comes out then faces to the left for a hose to go onto
same as the one in top of this pic but blue?
can someone tell me what size to get also
![](https://img444.imageshack.us/img444/6992/p6180003hl2.jpg)
if you dont rev your engine you will need a -10 -8 bulkhead fitting to screw into the camcover hole then you need a -10 90 fitting in quip your looking around £50 for them to items
how is it held into the camcover? do you need to tap the cover then thread a 90 degree in? i have a catalogue of fittings but all looks complicated
3/4 unf mate i have loads if you wana borrow one drill cam cover to 17.5mm and tap it i doubt you get a -8 bulkhead/-10 fitting as i had to turn a -10 -10 fitting down you can use a -8 bulkhead if you using 1/2 pipe for your breather but if its 16mm like most then ya need a -10 elbow fitting
hope this helps
hope this helps
well if there is enough meat around the hole may be tap to 20.5 and thread it -10 plus that way it will be cheaper as its a standard fitting needed if not enough meat then tap it out to 20x1.5mm and turn down a -10 fitting again
markk
23-08-2015 09:57 PM
