options for button for launch controll
Old May 21, 2007 | 07:02 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default options for button for launch controll
ok been having talks with stu about this launch control and how we are going to deactivate it, suggestions come up about swtichs under clutch pedal but still need another switch to deactivate the one under pedal for 2nd or 3rd gear.
being on the dash is too awkward
std steering wheels dont have buttons bar the horn.
but i have found something thats perfect but its king of tackyness
Old May 21, 2007 | 07:13 PM
jacko's Avatar
jacko
i like the fighter pilot type where you flip the top before you can press the switch
Old May 21, 2007 | 07:19 PM
Billabong's Avatar
Billabong
Microswitch on first, and a dash button to arm it?
i.e. dash button for overall 'on' state, and then microswitch on gear leaver that only allows activation when in first, disarming it when you change out of first.
Mike R had a boost control system setup similar to that on his old Sapph' I believe (for boost levels).
Old May 21, 2007 | 07:23 PM
Roosie's Avatar
Roosie
sounds good
Old May 21, 2007 | 07:30 PM
xr4x4rs's Avatar
xr4x4rs
Old May 21, 2007 | 07:42 PM
Roosie's Avatar
Roosie
Old May 21, 2007 | 07:44 PM
DanRSturbo's Avatar
DanRSturbo
Go baby go button
Old May 21, 2007 | 07:52 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
you want two buttons.....
one master to turn the LC on,
and one mounted on the clutch pedal, so when the pedal is right up the lc is off...
then you dont need any buttons as such to operate the lc, when the clutch pedal is down sat at the lights the lc is operating, when you pull off and the pedal comes right up it will switch off, when you are driving normally swotch the master off
used to have this system on an old car of mine ,had full throttle gear change too
Old May 21, 2007 | 10:02 PM
leecavturbo's Avatar
leecavturbo
why isn't your LC automatic?
mine turns off at a set speed!
Old May 21, 2007 | 10:57 PM
puddy's Avatar
puddy
On mine I have a hydraulic clutch and just use a pressure switch on the
clutch master cyl .
puddy
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sp3no
Sep 27, 2015 07:23 PM
