GT30 & T38 TURBOS-Update...Compressor map needed!
APART FROM THE BEARING CORES, WHAT ARE THE ADDITIONAL DIFFERENCES TO BOTH OF THESE UNITS?
(EXCUSE CAPS, I'M DOING CUSTOM ENTRIES............)
Former Sponsor
yup...
but as they re commercially derived, they are great on low blow ie diesel tractor/plant machinery engines etc..
but when masive power with such quick accelerating/decelerating enigne, ie cossie and the like, the heat created is much greater, and the gt suffers from this
carl
carl
(camp)B9KOS
Mate you dont know the half of it! I'm sure she's told Martin to ignore me!
Carl,
So that'll explain why the water needs connecting & you cant run Anti lag (but then if it spools up faster, surely the ALS becomes a toy??)..
Carl,
Football Cwazy
Good thing with the T38 is it's a good strong unit, near bullet proof,like the T34
i have heard you can run anti-lag on them, but i don't know if that is 100% fact or not.
Former Sponsor
well, they spool up faster, but they aint a massive difference, so antilag can still be used effectively
the big power skylines/evos/supras etc, run gt series, but they are usually 1/4 mile cars, and are expected to have a short life
when i say they suffer at big bhp, i mean like 600 +
for a road car they re good, but if not looked after they will spit their dummy quicker than a virgin spitting cum
the amount that we get that need to go in the bin is shocking
because of delicate parts, immaculate oil is needed when running decent power
Football Cwazy
i meant that i'd heard about people using them to run anti lag as they come, without any other special parts being fitted.....i know mine cost about a grand (with exchanging a T4 variant too!!) so it bloody should LOL!
Intresting reactions, i'd be more inclined to go for a turbo which Martin suggests TBH....
But obviously i knew there was an issue with regards to anti lag and its effects on GT series turbos.
DEYTUKURJERBS
WTF carl Wheres your experience of this?
commercially derived no more than any other fucking turbo
only usually on 1/4mile cars, yeah, right-o
when most peoples big boost T34s only last a year or so hard use, the whole thread here is pretty comical
Originally Posted by Franco
Originally Posted by Dan@Rapid-Ford
I thought the T38 was a step inbetween a T34 and a T4
Which in theory would mean it will spin up like a t34 but flow more air becuase of the comp housing - and surge its tits off
I suppose I'll have to see how mine goes. I've got the early one TT one
My HG-T38 pulls like a train to the limiter, doesn't run out of puff. Isn't any laggier than my old 'T34', and doesn't surge.
Franco, listen to Martin - he built your engine.
Originally Posted by radiant red
Dont know much about the differences but i can say the t38 TT unit is on full boost at 3600 (32psi) and its a very strong unit. Well recomended
What the spec of your engine? if you don't mind me asking.
saff is working!!!...atm
Almost there!
Franco, as Bill has said - listen to Martoon. see what he recomends for the engine that 'HE' has built!!!
hi lads
i have never had a t38 so i cant really comment
all i know that my gt30 makes positive boost at 2500 rpm in 1st gear
i dont have any surge issues at all
I think it is a great turbo but they are most defo weaker than the old "T" range
i dont you why you dont try a "T" 34 with the GT roller bearing cores inside them they make very good power aswell performance ford did a test on them and they made a hell of alot of power over the t34 with the old stuff in it
getting back to the gt30 with the internal waste gate i think its a good turbo i dont know how long it will last as for the power on what it can make im not sure
I cant wait untill it's live mapped i recon it will be good enough for me ill be very happy if it makes a gen 420bhp that will do me more than enough for track use
marco
marco
Former Sponsor
stavros,...
a) my experience is the x amount of customers that have binned the gt off and gone for t seires, and almost all had the same issues...heat soak of the core
b) oh, and where did i state that the gt seires "only usually" (which is a contridiction in itself) used in quater mile, as i was referring to anti lag setup....not exactly common for road cars to have anti lag...
c) i also meant that the gt series is most commonly used in low blow equipment.....ie :anything diesel
1st and 2nd see about 30 psi then its up to 32+ psi the rest.
so is there a way of adding extra cooling to the GT then as i f i have been reading write, if cooling can be advanced the GT series would be a winner??
Former Sponsor
its not the cooling thats the problem,
its the bearing housings
they re not made of the same material as the t series, and are more susceptible to "expanding" inside the housing around the shaft, causing shaft movement
as siad....
for road car use, they re great units
as siad....
The fella at turbo technics were explaining to me how the cores are ok untill they they get over heated then its goodbye core hello empty wallet this is why they cannot warrent them. Apparently they are developing a roller core to slip into a reguler turbo so we can swap them over,he did say it is in distant future. Something to look out for tho.
Can anybody supply me with a compressor map for a T38??
Martin wants to see one to compare against a GT30 map!
Also is there a difinitive anwser to how much hp a GT30 will make running at MAX - Seems to be a grey area..... MAD lot maybe?
Ps Mike R............
Before you start, See below!:
T38 - roller-bearing core
Full ceramic roller bearing core at both ends, brand new - 44lb air flow - good for 460+bhp. Delivery is EXTRA - cost is outright.
Ł1,100.00
Details
T38 - standard core
360° bearing, 7° cut back blades. This flows 43lb - so good for 450+bhp. Delivery is extra - cost is outright.
Ł950.00
Details
Ł1,100.00
Details
T38 - standard core
Ł950.00
Details
Ł1,100.00
Details
T38 - standard core
Ł950.00
Details
Ł1,100.00
Details
T38 - standard core
Ł950.00
Details
Caraholic
For people's information, please note that not ALL T38s are the same. The ones that I do have both the compressor AND exhaust housings machined to take bigger front AND rear wheels (hence the increased airflow). Please note that I have been conservative with the power out-puts, and depending on what spec the engine is, more should be able to be gained if the turbo is pushed hard (as can be seen by the fact that a normal T4 goes all the way to 520bhp and that only flows 48lb of air!).
Turbo Technics claim that that their T38 is good for anywhere between 420 and 480, obviously i think the 480 is a bit high but 450 must be about right on a well specced engine
Caraholic
