Removing ABS from a series 2.
Anyone know what i have to do to remove the ABS from my series 2? Ive got the gearbox out at the min so can kill two birds with 1 stone.
Thanks J.
Thanks J.
Neither-
Do A search......
When you remove the abs modulators you just reconnect the 4 pipes up. You will need to cut and make your own and either keep the diagonal link or change it to front/rear split- you will need to trace the lines to work out which 2 to join up to do it either way.
You then blank off the pipes that come out of the top of the modulators and go into the side of the plastic reservoir.
If you do a search you will get a much better and more detailed response
