USB computer stuff help..................
Old Sep 19, 2004 | 09:12 PM
RichardPON's Avatar
RichardPON
Default USB computer stuff help..................
Just purchased a Multimedia card reader so I can get the pics of my Nokia 6230 phone on to the computer.
Running XP, so it should just come up with removable disk when you plug it into the USB port.................. which it does.
Try and open it, and all it says is "please insert disk into drive f" (f is USB port.............)
Doing my head in - USB port appears to be working fine..........
Old Sep 19, 2004 | 09:18 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Might sound obvious, but, did you put the card from your phone into the reader ?
Old Sep 19, 2004 | 09:19 PM
Jamz's Avatar
Jamz
Do you have the card reader plugged straight into the back of your PC or do you have it chained off another USB device ?
Old Sep 19, 2004 | 09:20 PM
RANJ's Avatar
RANJ
whack reader direct to pc is it isnt already, they dont liek hubs usually
RichardPON's Avatar
RichardPON
It's just using a USB extension lead, as there's two ports on the back of the puter.
Have tried it both with the lead, and plugged directly into the port, and it makes no difference.
Yes, card is in the reader
Old Sep 19, 2004 | 09:22 PM
RANJ's Avatar
RANJ
chinny
gointo dos
type f: then press enter
will it let u access his way
if not,then possible driver/hardware issue
Old Sep 19, 2004 | 09:56 PM
RichardPON's Avatar
RichardPON
Ranj,
Cheers, but how do you get into DOS?
Old Sep 19, 2004 | 10:06 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
Start - run- type CMD in box and press enter
Old Sep 19, 2004 | 10:07 PM
frog's Avatar
frog
Start, run, then type cmd in the box and press [return]. Should get you a black window with a prompt.
Old Sep 19, 2004 | 10:11 PM
RichardPON's Avatar
RichardPON
... and it says "the device is not ready"?
Old Sep 19, 2004 | 10:13 PM
Chrissy_bwoy
did it come with any software etc? perhaps try reinstalling that
if not id say the card reader is fecked
Old Sep 19, 2004 | 10:19 PM
frog's Avatar
frog
Did you try the usual microsoft fix ?
REBOOT...
Old Sep 19, 2004 | 10:29 PM
Chrissy_bwoy
REBOOT...
Old Sep 19, 2004 | 10:35 PM
RichardPON's Avatar
RichardPON
REBOOT...
Yes
Old Sep 19, 2004 | 10:39 PM
RANJ's Avatar
RANJ
sounds liek driver/hardware issue
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
AJC
Oct 1, 2015 06:47 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
