PC help please
Old May 15, 2007 | 09:50 AM
PastyKing's Avatar
PastyKing
Default PC help please
is it important to put heat transfer compound on top of the processor?
i cleaned it off not knowing what it was a while ago when i took it apart to clean it
ive been given a tube to put some more on but is it important?
Old May 15, 2007 | 09:59 AM
AndyBlackFRST's Avatar
AndyBlackFRST
I've always been told to use it when putting a fan on the processor
Old May 15, 2007 | 10:36 AM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Your defo meant to use it and i always do . But i doubt ur notice anything by not using it unless your are overclocking the cpu and really pushing it hard.
Old May 15, 2007 | 10:47 AM
PastyKing's Avatar
PastyKing
ive put some on it now anyway as the fan was always kicking in and the pc is generally getting quite noisy
Old May 15, 2007 | 11:48 AM
patchST's Avatar
patchST
I wouldn't run a system with out thermal paste, your machine may run without it but I wouldn't personally.
I recommend http://www.aria.co.uk/Products/Compo...productId=7774
My system dropped 20 degrees celcius under full load using it compaired to
the standard stuff that came on my heatsink and fan.
It's only Ł4 and well worth it and should do about 100 cpu's
Old May 15, 2007 | 11:49 AM
nilrem's Avatar
nilrem
STOP!... Carry on
YES YES YES & YES!!!! you will fry most processors without it!
Old May 15, 2007 | 12:12 PM
BM08's Avatar
BM08
ive never installed a processor myself but i visit 2 pc forums pretty often and there always saying use thermal paste etc, and after you red up about it, then it all becomes clear, plus for a few quid and a few seconds spreading the paste its not worth leaving it out and then frying something
Old May 15, 2007 | 01:21 PM
DanRSturbo's Avatar
DanRSturbo
None of my 3 previous CPU's had thermal paste on them and i never had any problems, it's not a requirement unless you plan on overclocking it or putting it under heavy load all the time, in which case buy a bigger fan to compensate as well.
Old May 15, 2007 | 01:38 PM
m4cK's Avatar
m4cK
If you want your CPU to run more effeciantly and last longer use thermal paste !, if you don't you could risk damaging your CPU, specially if its an AMD chip as they run hotter then Intel chips.
Old May 15, 2007 | 02:01 PM
phil_focus's Avatar
phil_focus
dont fully agree with you there.
the AMD sempron chip's run cooler than normal chips!
Old May 16, 2007 | 03:18 PM
dale_jeffs's Avatar
dale_jeffs
yea i think it is quite important. when i was usin my PC the processor fan used to run really loud. so i took that off and replaced it with a better fan and they told me you HAVE to use it.
