please help! msd closed loop prob
Old May 14, 2007 | 08:49 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default please help! msd closed loop prob
My car has had a surge problem since i built a new engine.
had it on a gas analyzer today ,and it surges because its so weak 0.45% at idle.. and thats max on the ecu fuel adjuster if i unplug the lambda sensor the co raises to over 6.00% because its obviously max rich ,but it does idle nice rich not hunting like it does when weak.
the fuel pressure is 3.5 bar pipe off.
so i get home and take the plugs out No 1 plug is wet and black with fuel but all the others are ok/weak white. the problem must be to do with the rich cylinder making the lambda weaken off ,and this in turn is making all other cylinders weak
what can make no 1 rich? i swapped plug and injector and its exactly the same
Old May 14, 2007 | 08:53 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Get the injectors flow tested mate, sounds like No1 is dodgy.
Boschman does it for a very good price
Old May 14, 2007 | 08:54 PM
ECU Monitor Enthusiast
As you have changed the plug and injector (or swapped them around)
It COULD be a fucked plug lead or dizzi cap causing a missfire....
OR... ( along shot)
I had a similar issue on my ecu but that was caused by the crank sensor
and/or the phase sensor miss adjusted and also damage on the crank
pulley and causeing the ecu to think the car was continuously starting
causing the first injector to fire twice. (This was on a P8)
Old May 14, 2007 | 08:59 PM
JTECH James
Passion for Fords!
holy shit!
Old May 14, 2007 | 09:00 PM
JTECH James
Passion for Fords!
its not misfiring..deffo on all four ,i swapped a lead and made no difference,
need to look at the crank/phase sensor then! thanks!!!
Old May 14, 2007 | 09:04 PM
Cant be a fuel pressure problem as it would affect ALL cylinders.
Unless your ecu injector 1 driver transistor is dead or dying.
As another test, (for the above)
swap injector plugs over on cylinders 1 and 2 they should just reach.
The car will NOT be damaged by this, but dont drive it hard for more than
a few seconds in case another fault is hiding a bigger problem.
ALso, there maybe a bit of throttle hesitation while doing this at low rpm.
If the fault moves then I would say you have an ecu problem or as I suggested
above a crank/phase sensor issue.
Old May 14, 2007 | 09:07 PM
JTECH James
Passion for Fords!
wouldnt it misfire if the no 1 driver was dead?
i will try this thanks for your help mate!
Old May 14, 2007 | 09:09 PM
If the driver was on the way out, they can act like a delay so extending the actual pulse without the ecu knowing.
Had the same probelm once on an L6 ecu and that uses the same drivers as L8 and P8.
Old May 14, 2007 | 09:10 PM
JTECH James
Passion for Fords!
ahh i see! is the fault fixable or is it new ecu time? if it was this
Old May 14, 2007 | 09:12 PM
Piece of piss to fix
(If it is the problem)
I have over 300 of those transistors for that here
Old May 14, 2007 | 09:13 PM
Bugger, This isnt a for sale post
JTECH James
Passion for Fords!
do you do ecu testing?
Old May 14, 2007 | 09:15 PM
Yes I can test it for you, but I would just check the Phase, Crank sensors
and the crank pulley all look ok first !
Old May 14, 2007 | 09:16 PM
JTECH James
Passion for Fords!
wil do mate! im sure i do have a wobble on the crank pulley.
i just thought if it ran on all four it must be ok
Old May 14, 2007 | 09:18 PM
See if Doug (L8ECU) would lend you an L8 as I dont have any myself
just to make sure.
*** Doug assures me he isnt a trader despite the name
Old May 14, 2007 | 09:19 PM
JTECH James
Passion for Fords!
if needs be i could get a L8 of someone easy...
i'l check these things first though! thanks for you help
Old May 14, 2007 | 09:50 PM
JjCoDeX75's Avatar
JjCoDeX75
I have one on the shelf if you require, James
JJ
Old May 14, 2007 | 10:01 PM
Stu @ M Developments's Avatar
PassionFords Creator
But all was well before you rebuilt the engine?
If you unplug the ISCV does teh engine speed stay in the 900s? If not, fix that first as the engine needs to stay above 800 for the loop to work correctly due to teh breakpoints ive used in teh map. However... this sounds a wierd one, but dont dont discount a faulty FPR spraying fuel into teh plenum via the compensation pipework.
Old May 15, 2007 | 07:42 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you haven't connected the iscv plug to an injector by mistake have you?
Old May 15, 2007 | 12:14 PM
JTECH James
Passion for Fords!
deffo not mate
Old May 15, 2007 | 12:16 PM
JTECH James
Passion for Fords!
If you unplug the ISCV does the engine speed stay in the 900s? If not, fix that first as the engine needs to stay above 800 for the loop to work correctly due to the breakpoints ive used in the map. However... this sounds a wierd one, but dont dont discount a faulty FPR spraying fuel into the plenum via the compensation pipework.
it all seemed good before the build stu, makes me look toward a sensor set up being more likley?
Old May 15, 2007 | 06:59 PM
JTECH James
Passion for Fords!
Right so....
i get home today ,and remove spark plugs 1 and 2, cleaned them so they both look identical, gave the cylinders a min or two for the excess fuel to evaporate so both piston crowns are dry....
swapped the injector wires as simon suggested and ran the car for a few mins
the problem stays with no 1
i did the test a few times to make sure..and same results every time, no 1 plug gets wet and the crown is also wet.... didnt go black as i didnt run it for long enough, plug two looks clean and dry
so i now have checked... plugs and cap lead etc... base idle with iscv unplugged is dead on 900rpm, and idle is now uneffected when the iscv is plugged back in, fuel pressure, pressure tested for air leaks at 1, 2 and 3 bar, swapped injectors over and done the above test and still have one rich cylinder no 1....
what can it be? fuel reg as stu suggested?
im wondering if i have stumbled on the reason my engine melted no 4, as i may well have been weak
Old May 15, 2007 | 07:02 PM
Swap the point where the fuel pressure regulator gets its vacuum with
say the dump valve and see if the problem moves.
Also, with the engine going see if petrol comes out with the pipe off.
If this isnt the problem, You may have a valve or cam issues
Old May 15, 2007 | 07:06 PM
JTECH James
Passion for Fords!
compressions are dead even across the four cylinders, if i richen it up to say 2% by unplugging the lambda sensor... the engine runs sooo sweet i cant see it being a mechanical issue
i will check the vaccum but its got a seperate plug on the plenum
ohh this car
Old May 15, 2007 | 07:12 PM
JTECHSAFF,
Just reread you post above, any failure in the closed loop system
(If there is one) will cause the system to revert to standard maps settings
and run slightly rich across all cylinders.
Besides above about 2 to 3 psi, the closed loop control will be deactivated anyway.
Swapping the injector wires shows it isnt an ecu problem IMO.
Barring any mechanical issues....
The more I think about it, I am going with an ignition related issue.
Did you swap the cap, lead and rotor arm ?
Old May 15, 2007 | 07:27 PM
JTECH James
Passion for Fords!
the cap and arm are new, and i swapped a lead over.
doesnt misfire at all though, deffo always on all four, at hte moment its actually running ok, but still rich on no1
just done the above test mate and no fuel comes out the reg pipe, and didnt make a difference swapping vaccum
Old May 15, 2007 | 07:31 PM
JTECH James
Passion for Fords!
maybe its a lifter problem? one not opening enough? and causing the fuel to drop onto the cylinder rather than spray in?
Old May 15, 2007 | 07:36 PM
It is possible to part ignite a cylinder with a weak spark.
I am sorry to say its sounding like a mechanical issue ......
Could be a tappet or valve not seating properly.
Compression tests are done at low speed and at relatively low pressures
so may not cause the problem to appear.
DONT rip it apart just yet, I will have a think and I am sure others will
add suggestions too.
Old May 15, 2007 | 07:45 PM
JTECH James
Passion for Fords!
thanks mate... thankfull for your help here
when the engine was apart it had cosibro valve guides and seat were cut and lapped in by a local firm who are well trusted
Old May 15, 2007 | 07:46 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
have you tried swopping number 1 and 2 injector unit round, to rule out a duff injector?
Bri.
Old May 15, 2007 | 07:47 PM
JTECH James
Passion for Fords!
yep done that mate
Old May 15, 2007 | 08:49 PM
JTECH James
Passion for Fords!
does anyone know what pins on the ecu are for injectors one and two so i can compare the duration just to double check its not double firing?
Old May 15, 2007 | 08:50 PM
JTECHSAFF,
How are you going to measure the duration ?
Old May 15, 2007 | 08:52 PM
18 INJECTOR 4
32 INJECTOR 2
33 INJECTOR 3
35 INJECTOR 1
Old May 15, 2007 | 08:54 PM
JTECH James
Passion for Fords!
my carlo fandango multimeter can measure injection pulse in m/s
Old May 15, 2007 | 08:58 PM
No it cant
Low impedance injectors on the weber ecu's have strange driving signals
that will fool 99.9% of duration testing multimeters and give false readings.
The ONLY way of doing it properly is to use an oscilloscope - Sorry
Try it and let me know the results.
If you can wait till Sunday, I can come down to you and we can
check over your car thoroughly with my scope and diagnostic equipment.
Old May 15, 2007 | 09:01 PM
JTECH James
Passion for Fords!
cool!
i have got a scope, but im sure you know alot more about this then i do!
Old May 16, 2007 | 08:08 PM
JTECH James
Passion for Fords!
i swapped the lifters tody and got the running in oil out of it.
made no difference
Old May 16, 2007 | 09:30 PM
JjCoDeX75's Avatar
JjCoDeX75
Shit news matey - hopefully Simon will be able to diagnose this on Sun.
JJ
Old May 16, 2007 | 09:33 PM
JTECH James
Passion for Fords!
not sure what will happen, im on my stag night on saturday, but hopefully i will survive
