where do aftermarket speedos and rev counters take info from
im thinking of putting Autometer rev counter and speedo into my dash were do they take there information from ie does the speedo run from original speedo cable or do they use there own.
Speedo will most likely be ELCETRONIC ?, so will have sensors fixed to prop then there will be a series of DIL pins to set to get as near as pos to accuracy.
Tacho uses the oe signal.
Speedo will be able to tap into the vehicle speed sensor, the rev counter can be made to work off pretty much anything, such as one of the coil -ve's
