A question to Ford CVH and Cosworth Owners with L8 ECU's...
Old 10-05-2007 | 10:06 PM
  #41
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by Davey C
How much and when can I get it
This is, as yet, unconfirmed until all software and hardware is tested and confirmed as running 100% as expected. labour and hardware costs need to be considered and development costs recouped. It will be cheaper than doing it on a P8, put it that way.
Old 10-05-2007 | 10:07 PM
  #42
S2martin's Avatar
S2martin
Ex Full Price gold member
Do you now wish you kept your cossie Stu? what with all these new and exciting developments??
Old 10-05-2007 | 10:10 PM
  #43
Kelv's Avatar
Kelv
Almost there!
Originally Posted by Stu @ M Developments
Originally Posted by Kelv
Also, can you buy the softwear or have it fitted by yourself to run the anti lag / launch control / coilpacks etc and then still have it mapped by your own engine builder to there requirements?
Sadly not.
ALS and Launch control software will be contained within the calibration Eprom of the Level 8 ECU, thus it will only be available with my own maps on it. It MAY be possible at a later date to incorporate other peoples maps into this software for a price, but i am not currently very happy with the prospect of being the last person to touch a map, so to speak, just in case its garbage and was about to kill something... if you follow?
Wasted spark of course can still be fitted to any ecu regardless of mapper. Just as it always was.
Cheers Stu, i vaguely follow
My main point was, with Martoon currently building my engine, and then arranging the mapping side of things for my car all on L8, would there have been the possibility of having the added feature of your software, namely 'Launch Control' added to it!?
  #44
markk's Avatar
markk
Originally Posted by Roosie
i maybe interested but how much hard work to convert to anti lag apart from stronger turbo?
A switch (or 2 if you have LC too) on the dash
ALS valve.
ALS throttle body
Those are minimum requirements.
However we will also be able to run perfectly normal idle control valve strategies too if you wish to fit bigger and better bypass valves elsewhere. Unlike the shonky pectel P8 version.
now come on stu, you know how ive been running all this on P8 with no issues whatsoever, i dont even suffer this so called 'high revs' on cold start, dont put kenny down, he is a bit good with P8
Old 10-05-2007 | 10:20 PM
  #45
Nope.. they were underway when i still had her.
I just yearned for a normal, newer smelling, quiet and comfortable car to drive home in. I am still enjoying that after 15 hard years of Cosworth daily driver...
  #46
Sadly not.
No, it cannot be added without adjusting the map, and most mappers will encrypt their map so we cant adjust it.
Old 10-05-2007 | 10:21 PM
  #47
4x4 ste's Avatar
4x4 ste
Originally Posted by boosthappy1
Could all this be happening
to a lovely white 3 door you have up there mate.
It sure is.
Thanks to Steve Whittaker and his beautifull 500Bhp 3door, i have a test mule for a week or 2 to complete the project with Nikola and also Simon, as he is helping us with some spark drive related issues.
No problem mate, i cant wait for the drive home and thanks to Nikola and Simon for there help in getting my car sorted
Sounds like your turning my car into something a bit special We will have to get a few beers sorted soon and lets keep the lap dancers in a job
Cheers Steve
Old 10-05-2007 | 10:22 PM
  #48
Originally Posted by markk
now come on Stu, you know how ive been running all this on P8 with no issues whatsoever, i dont even suffer this so called 'high revs' on cold start, dont put kenny down, he is a bit good with P8
He is indeed Mark. He is indeed.
Old 10-05-2007 | 10:24 PM
  #49
It sure is.
Cheers Steve
Your right, she will be the very first of a new breed.
We will arrange a meal and a few beers for when you pick her up mate. Thanks again for your very kind help.
Old 11-05-2007 | 10:17 AM
  #50
Dave Henshall's Avatar
Dave Henshall
this does sound interesting
wish i still have a cossie to play with in my spare time aswell as the ST for daily driving
Old 11-05-2007 | 10:35 AM
  #51
Why not L6, saves me buying another ecu then!!
Old 11-05-2007 | 10:58 AM
  #52
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Re: A question to Ford CVH and Cosworth Owners with L8 ECU's
Can you imagine having your Level 8 with:
Wasted spark.
Closed loop fuelling control.
Pectel compatible serial datastream output for diagnostics.
Yes, how much (out of interest, I have no spare ŁŁŁ's at the mo )
Is the datastream documented so that someone who understands computers and RS-232 can do something with it ?
And as Tabetha said - how about L6 ???
Old 11-05-2007 | 12:45 PM
  #53
Roosie's Avatar
Roosie
500bhp Cosworth in making
bechause i have closed loop and wasted spark and say i wanted als does that mean i have to buy the whole lot again and include als or can it just be added or reprogramed
Old 11-05-2007 | 03:27 PM
  #54
It means you must give your present ecu to me as a gift, roosie, then go buy another one!!
Old 11-05-2007 | 04:28 PM
  #55
Rick's Avatar
Rick
It looks like you're at quite a low level with the IAW now. Implementing CAN bus would sort your I/O worries
Old 11-05-2007 | 05:16 PM
  #56
ECU Monitor Enthusiast
Rick,
There are far easier ways of extending I/O without the complexity of CAN bus LOL
Old 11-05-2007 | 05:36 PM
  #57
xr4x4rs's Avatar
xr4x4rs
sounds very interesting especially the coil on plug
any ideas when this new stuff will be available?
Old 11-05-2007 | 06:56 PM
  #58
Rick's Avatar
Rick
LS35A
CAN buses Rock!
How would u do it? Multiplex?
Old 11-05-2007 | 09:23 PM
  #59
col cos1's Avatar
col cos1
very intrested in this
Old 11-05-2007 | 09:28 PM
  #60
Originally Posted by Rick
LS35A
CAN buses Rock!
CAN in the right enviroment does rock.
All thats needed is extra inputs added to the existing CPU bus.
2 chips, a few resistors job done.
Old 12-05-2007 | 10:43 AM
  #61
Will answer later chaps, bit busy at Mo with some shonky S1....
Old 12-05-2007 | 07:06 PM
  #62
I should know a LOT more on Tuesday, as i will be hopefully spending most of tomorrow playing with it all on Steve's car.... if all goes to plan at Nikola's end.
Old 12-05-2007 | 07:20 PM
  #63
4x4 ste's Avatar
4x4 ste
Let me know how it all goes mate im like a kid at christmas at the moment
mmm I really should get a life
Steve
Old 12-05-2007 | 08:21 PM
  #64
slowpoke's Avatar
slowpoke
what ecu is in a 4x4 saph ?
thats l6 yes ?
Old 12-05-2007 | 08:28 PM
  #65
GARETH T's Avatar
GARETH T
L8 in a 4x4
  #66
4x4 ste's Avatar
4x4 ste
thats l6 yes ?
I thought they were l8 and l6 were 2wd saff ?
Steve
Old 12-05-2007 | 08:37 PM
  #67
Dave Henshall
thats l6 yes ?
Steve
correct, and L1 in 3 door
Old 12-05-2007 | 10:44 PM
  #68
xr4x4rs's Avatar
xr4x4rs
thanks mate
as i will be ordering coilpack conversion and new chip soon so may aswell wait until your all sorted and get it all together
would the engine loomneed modifying for the extras or is it all in the ecu
Old 13-05-2007 | 04:48 PM
  #69
Mr C's Avatar
Mr C
I already have a L8 with a MSD Evo chip on my Stg3 2wd, looking to plumb in my ALS T34 turbo and go coil pack/wasted spark anytime now so this is excellent news, would like to get all the parts for the conversion from yourself including any bypass valve etc Cant wait for the coil on plug set up too, is this aimed more at high powererd/motorsport applications or recommended at Stg 3 power? Good news . Mark.
Old 13-05-2007 | 04:52 PM
  #70
No loom mods needed unless you opt to have ALS in its own bypass housing and retain teh full ISCV strategies.
Coil On Plug doenst really benefit you a great deal over wastyed spark until at very high BHP indeed. (600+) or you are running NOS.
(Nos and WS dont really work well together due to a small inherent risk)
Old 13-05-2007 | 05:03 PM
  #71
xr4x4rs's Avatar
xr4x4rs
if i was to have anti lag it would just be a mild one tbh
as i dont really want ti fork out for a maram shafted turbo just yet
but thats good know theres no mod to the loom
but what about turning it on and off will just be a switch
Old 13-05-2007 | 05:08 PM
  #72
Yes, single switch on teh dash mate.
Or 2 if you opt to have launch control as well.
Old 13-05-2007 | 05:11 PM
  #73
JjCoDeX75's Avatar
JjCoDeX75
Sounds pretty good, Stu!
I wasnt aware that ALS could be switched off so as to speak - so when off, it runs like a normal car then? (well as normal as my cosworth ever manages anyway ROFL!)
JJ
Old 13-05-2007 | 05:15 PM
  #74
xr4x4rs's Avatar
xr4x4rs
thats great
very interested in anti lag
launch control possibly, maybe save my gearboxes on hard launches as its 4wd
Old 13-05-2007 | 09:20 PM
  #75
JJ
Indeed sir.
Old 13-05-2007 | 09:36 PM
  #76
JjCoDeX75's Avatar
JjCoDeX75
Hmmm - very cool!
Maybe a project for the future if I keep the old girl!
JJ
Old 13-05-2007 | 10:35 PM
  #77
Deltona's Avatar
Deltona
A clip of Nikola and friend doing some initial testing the first ALS on an old 8v Delta:
http://www.youtube.com/watch?v=IO6I1...elated&search=
As you can hear, it just pops, this is due to the standard twin silencer system, which eventually gave way....
http://i103.photobucket.com/albums/m...haust1_197.jpg
Another one, this time on a 16v Evo:
http://www.youtube.com/watch?v=Qmbhl...elated&search=
Make sure you have a good exhaust as well as a strong turbo!
Personally I think it's great what Nikola can do to a standard ECU and am looking forward to getting the results of his work through MSD over here.
Old 13-05-2007 | 10:40 PM
  #78
markk's Avatar
markk
shame i dont have my car anymore as it would have bee the ideal test mule
Old 13-05-2007 | 11:40 PM
  #79
SS1's Avatar
SS1
Old 14-05-2007 | 07:43 AM
  #80
frog's Avatar
frog
Dare I ask how the traction control works ?
The ECU doesn't see any speed reading does it ? The only thing I can see being related to traction control the ECU would see is RPM
Just being curious
Quick Reply: A question to Ford CVH and Cosworth Owners with L8 ECU's...
