mk1 escort transmission changing?
hi, i was just wondering wether it would be a hard job to change a mk1 escort 1.3 l, from automatic to manual. any info appreciated regards ashley
quite easy job
You have to change the paddlebox. I always adapt the automatic paddlebox with an clutch paddle and make it fit. It's easy! I don't use the paddlebox from a manual version, because this one is hard to make fit.
Then you have to make a hole for the clutch cable, and you have to replace the hole from the gearlever about 10cm (about 4") to the back.
And you have to place a complete clutch set incl. clutch bearing.
The original gearbox mounts won't fit (because the tunnel is wider). So you have to make 2 mounts for the gearbox. Ow, and don't forget the start engine, it's different from an automatic version!
I've done this job normally in about 5hrs
But why not replace the "slow" 1.3 for and 2.0 with 5 speed gearbox???
