How much boost???
Old May 6, 2007 | 06:51 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default How much boost???
hi guys, my 4x4 saff is running a stage 1, 280bhp how much boost should it be running roughly, im boosting 13psi but its holding 12psi is that about right? as the guy i bought it off said he turned the boost down when he was travelling down the motorway to bring me the car. thanks in advance.
Old May 6, 2007 | 06:55 PM
Jasesapphy's Avatar
Jasesapphy
usually 1 bar so 15psi
Old May 6, 2007 | 06:56 PM
14/15 psi.
Old May 6, 2007 | 06:57 PM
OrionRST200bhp
is that normall for stage 1 or is it best just to get it set up on the rollers?
Old May 6, 2007 | 06:59 PM
bud-weis's Avatar
bud-weis
Football Cwazy
normal is about 1 bar like they say.
i'd get it checked out regardless...for the sake of £100 odd quid you'd be daft not to make sure it's running right
Old May 6, 2007 | 07:00 PM
OrionRST200bhp
cheeRS guys
Old May 6, 2007 | 07:47 PM
Jim Galbally's Avatar
Jim Galbally
if the car was known to be running properly, why on earth would they turn the boost down to drive it down the m/way?
something fihy from that comment, so i'd DEFFO get it checked over!
Old May 6, 2007 | 08:24 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Get it checked out. Mine drives so much better since I had mine done. As stated for the sake of £150 its worth it for the peace of mind.
Old May 7, 2007 | 07:31 AM
£100/£150 just get a fuelling check 20 minutes cost you at most 1 hours labour rate, mine charged me £20, they will set boost so you have correct AFR which is the important thing.
Old May 7, 2007 | 12:48 PM
Jim Galbally
obviously a very comprehensive setup for 20quid
Old May 7, 2007 | 12:53 PM
boost mad's Avatar
boost mad
it depends on the chip to what boost..... defo get it checked out !
Old May 7, 2007 | 01:38 PM
It takes minutes to do a power run to see AFR.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
