focus rs head vs blacktop head whats the difference?
i just got me a 30k focus rs bottom end for £300 now i need a head but will a blacktop head be ok?
i have the cams from the same engine so all i need is a rocker cover and a head to make it compleate
all i know it the valves are made different. so maybe get some new valves for a blacktop head?
the chap i got the engine from says a rs head is worth around £400 and sujested that i fit a st170 head and block off the oil pressure for the vairable valve timing and fir the rs cams in that
so what do you think?
Originally Posted by ©hatter Box
the st170 is the better one but its a bitch to change over as its got fft
thought i saw someone on here mention getting a kit or something to disable the vvt???
i managed to find a head from a 1.8 mondeo for £93 and covers 50k miles
it stll looks like new inside!
it has 1.8/2.0 inside cast in to the head si i'm presuming this will be ok to use on a focus rs lump
so whats it like sorting the shims out?
The cams are thicker as well if i'm not mistaken. If you get a black top head make sure the code on the front starts with AA as the BB codes are 1.8l There is a difference in the combustion area equating to about 5cc i think. Check with Ian Howell to confirm the difference.
humm crap my head i just bought for the FRS bottom end ends with bb
i have genuine focus rs cams
XS7G-6090-BB
and 46 K4 TEA next to the thurmostat housing
so do you think im looking for trouble using this head ?
its using aftermarket management so it's just going to be live maped
and if you look where the head bolt goes near the cam sensor it says 2.0/1.8
XS7G-6090-BB
saph in dorset
14-08-2015 10:10 AM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
