Anti lag
its not the throttle body, its the idle /bypass valve thats operated by the dash switch/ecu. u need a modded iscv & a suitable ecu to work
Originally Posted by BigErn
Fancyin a bit lagless fun Paul?
If I had the money Id do it! Shame theres not a cheap way.
Has anyone else done it who can shead some light on the best way round it ??
if you r using the standard throttle body u need to enlarge the bypass hole for more air to flow. speak to Mike Rainbird to get the iscv valve modded. then u will need tihe ecu modding or changing depending on car
not sure about l6 but l8 ecu will run it
mine is a mild setup and when activate raises boost pressure to zero. makes a hell of a difference to cornering. 1 downside is much less engine braking and of course turbo meltdown.
155lee
24-10-2015 11:11 AM
