Engine Advantages Rollers - Whats peoples opinion of them?
#81
Hi chip
convert your BHP power figures to Kw. 40bhp ~ 30kw. a lot of power lost (not lost, converted)
thats a lot of heating.
I don't believe the RR.
#82
Originally Posted by Billabong
To get an accurate flywheel reading, engine dyno' it.
Oh and potentially if it was run leaner too, if you look at all the SCS dyno plots of course!
(12.5 in the car? umm NO!)
When mapping for power, surely you 'map for power' and there's an 'ideal' AFR for power as I'm sure you're aware.
I'm not blinkered enough to think my car makes exactly the same power once in the car, as obviously there are things to be taken into account - hence why it's then tweaked/optimised once in the car.
1) map for a figure for the customer that it will never run
2) actually try and keep it in one piece at a lower figure
Of course not everyone puts the AFR on their dyno printouts, which makes it harder to compare.... but are you suggesting a mapper should deliberately map a car rich on the engine dyno? There's still a strong possibility it's going to be different once in the car (AFR)
Unfortunately no one's come up with a reliable device to measure flywheel horsepower in an in-car situation
track.focus'd
12-08-2015 05:53 PM
