Red key?!
Old May 3, 2007 | 11:26 AM
Turbo Pez's Avatar
Turbo Pez
Default Red key?!
Never got a red key with my car when i bought it, is there anyway of getting a replacement, its a 98 escort si?
Old May 3, 2007 | 12:41 PM
bluescortcossie's Avatar
bluescortcossie
i pretty sure they do it by changing everything , locks / ignition / immobiliser etc so its not going to be cheap
Old May 3, 2007 | 01:43 PM
RichieST's Avatar
RichieST
No they dont. It will need to go to fords to be re-programmed, my gf was quoted almost 100 notes for a new red key and for it to be programmed
Old May 3, 2007 | 01:46 PM
bluescortcossie
oh right , not as bad as i thought then
Old May 3, 2007 | 05:35 PM
filthyrichie's Avatar
filthyrichie
find a local locksmith , they do them as i have key programming gear for all makes , i charge 35 quid plus key
tools to ask for is ad100
or mvp
hope this helps
Old May 3, 2007 | 06:42 PM
I paid £45(fords) to supply red master and new black key for my mondy.
Old May 3, 2007 | 06:57 PM
Jim Galbally's Avatar
Jim Galbally
whats special about the red one? i use the red one for my missus escort, if it's special i might just get a shitty normal one cut and use that
Old May 3, 2007 | 06:59 PM
filthyrichie
red is master and used to program others but u usually need 2 keys including the red 1 to do it, keys from ford are 18.73 each red or black cut to number
i have the programmer and i charge 35 plus to code to vehicle
our lot round here charge about 150 plus vat for 3 keys coded at ford
Old May 5, 2007 | 09:04 PM
Turbo Pez's Avatar
Turbo Pez
Cheers mate, found a red key on ebay 10quid and cut to code, found someone local who will programme it for £25quid! Sorted
Old May 5, 2007 | 09:15 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Or you can remove the internals of the key and strap them inside your ignition cowling near the barrel....then whenever you use any key it will believe its accepting the red key cheapest method i've found yet.
Dan
Old May 5, 2007 | 09:40 PM
Turbo Pez's Avatar
Turbo Pez
Dan
I would but i wanna get the remote locking working a need the red key to do so!
Old May 5, 2007 | 09:45 PM
SillyFezzaMk1
Rubber Rhino Crew
Dan
Or if its got an alarm you can use the output off of that to triger the locking.
Old May 5, 2007 | 10:36 PM
MarkN's Avatar
MarkN
Did 98 cars still definately come with a red key? I thought they'd been dropped by then
Old May 6, 2007 | 10:03 AM
RichieST's Avatar
RichieST
my gf's 2000 X reg escort should have a red key. They dropped using them with the focus and later mondeos came about
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
