What do I need to make a........
FLAMER KIT
I just want one for the comedy factor of torching the front bumper of all these little chavvers in their corsas when they up close and personal at the lights
I don't want to go spending £100 on one, as i have a spare coil, plug, plug lead etc etc. Just need to know what kind of wiring/relays I need from my local motorfactor.
Cheers guys
Cheers guys
You just need a switch to supply the lead and the plug with current for the spark.
You will of course have to drill a hole in your exhaust and weld a nut to it for the plug to screw into.
Originally Posted by Lee_R21Turbo
How old are you.........
Rainbowbum, what's the score here duder??
And reading that ebay add, it says not to loop it into the ign system?? Surely you would have to relay it to cut the coil in the engine bay and therefore feed unburnt fuel into the exhaust system?
DEYTUKURJERBS
It lights the unburned fuel on the overrun.
IF you have any that is...
heres a vid of my old cossie with the flamer kit as you can see i had a lot of unburnt fuel
http://www.youtube.com/watch?v=kdcXNuBIiVM
dont know how much if any on my next one as im going closed loop hence not sure wether to fit it or not
So if I wanted to cut the ignition to get some serious 6ft flames, I would have to relay the positive feeds to both coils?
DEYTUKURJERBS
Your gonna easily out chav the chavs by the sound of it.
Time to fit a butane gas flamer kit by sounds of it
If you need to MAKE your car flame by increasing fuel or removing ignition, its total gayness.
Using a flamer to ignite any natural unburnt fuel (as long as u dont tell anyone ) is fair enough, better than black smoke.
But making it happen like your mentioning is just bent.
sod cutting the igniton that can cause problems may aswell rev it up and turn the ignition on on/off quick
go for what starvos said and have a butane gas canister in your boot and do it that way, some nice blue flames then
with the flamer it it burns as said the unburnt fuel in the exhaust yes it can be gay but it looks better than black smoke plus its while your moving aswelll or changing gears
none of this stood stil crap with butane or revving the fuk out the engine t=just to get flames at cruises
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
TPM961
15-01-2018 10:50 AM
SMILER258
28-09-2015 09:04 AM
