Which gearbox for Escort cossie running 500BHP
#124
this has been a bloody good discussion.and tbh,i think when the time comes im going for the mullit. i cant be doing with worrying that if i launch it at the pod or a set of lights its gonna go pop.ive had unbelievable luck with my whole car so far really and it can only last so long so i would like to cut down the chance of it going tits up on me.
i then have the worry of the diffs and shafts
MARCO.. the reason on the name
#125
1st to 200 without NOS
Ok, to clear things up price wise. This is how much the straight cut gearset costs....
Gearkit Ł2650,
1st gear set * Ł 250,
Mainshaft* Ł1000.
All prices are plus VAT
The items marked * are optional and have not been fitted to Porkies car, which at the moment is showing no signs of any problems..This gear box will shorly be removed and fitted to the Mondeo to see how it copes with sustained high speed runs and the effects a heavier car has on it when launching.
You will need a suitable donor gearbox as a base unit for the gearkit to be installed into, if the unit is in good order parts and labour are going to total around Ł300 (again plus vat).
This means that all in the gearkit built and fitted into your casing and ready to install will cost Ł3466.25 (based on a good base box)
Both Reyland and Marco are authorised sellers and the price will be the same from both.
Gearkit Ł2650,
Mainshaft* Ł1000.
#127
#128
#129
#132
Originally Posted by Chip-3Door
Marco, this isnt a pisstake question, so please dont take it that way as I know it may seem like it.
But is the entry level mullet box any better at fully bore launches than a standard box?
Its just I notice you saying "porkie's car has launched hard on one" but he is on standard first gear and standard shaft, so how is that a reflection on the mullet box, or is the support from the bearings etc better in order to better support the standard shaft?
chip
i fogot to mension that 4th gear takes some of the abuse/load when launching because it's on the same line as 1st ,so to say
marco
#133
I'm using Marco's mullit box for two months now and I'm very happy it's taking all the abuse no problem I'm doing a lot of lounching with my 500+ bhp escos and broke 4 std boxes in a month,before I found the right decission
#134
#135
#138
- what front diff you running?
doing the work for now
#139
Hi Martin
im glad your happy mate , if i can help you out with anything else just let me know
and 11.5 is a cool time
cheers
#140
some shady bidding last thing.
#141
2Evos & 1 Escort Van :-)
Wouldn't say wasted though as I'm sure the thick wall is good, just I never needed it.
Si
#142
Thing is sib, it's only 2 or 3 front diff failures before it has paid for itself by the time you have driven to pick up a spare diff, spent the time getting the thing in and out again, dropping my mate some cash for the use of his ramps etc, as I really can't be fucked hauling front diffs in and out every other week, I drive like a bit of an animal, although I am very mechanically sympathetic when I can be, I would rarther it be much harder to break than to just take a chance.....
#145
Originally Posted by Paul Ripley
So are all the gears on the mullit straight cut 2-5 and 1st and mainshaft as an option?
#146
Monte Geek
In the interest of learning/comparing and not slagging off
I have DPE Gearbox which has a Straight cut 2nd and 3rd with Standard 1st, 4th and 5th. I was told 4th and 5th aren't very prone to break.
Whats the difference between what I've got and the mullit other then not having straight cut 4th and 5th.
#147
RWD_cossie_wil
i never bid, i was watching right up to the end and some new ebay member,1 week he has been joined up for, he made the bidding go right to the limit,i thought this was a bit strange.
#148
RWD_cossie_wil
#150
Monte Geek
#154
#157
Caraholic
