Revving high question *UPDATED*
Old 28-04-2007, 09:28 PM
Physio
Physio's Avatar
Default Revving high question *UPDATED*
My 1st RS turbo question
The car's idling around the 2.5 mark which sucks the big one!!
The idling screw is all the way in so it cant be adjusted anymore - anyone got any ideas?
Old 28-04-2007, 11:19 PM
NUTS RuS
NUTS RuS's Avatar
Turn it off ?
Old 28-04-2007, 11:20 PM
aduz
aduz's Avatar
sell it
Old 28-04-2007, 11:41 PM
Chris69
Chris69's Avatar
get it setup at a tuners
Old 28-04-2007, 11:50 PM
NUTS RuS
NUTS RuS's Avatar
Put a longer screw in ??
Old 28-04-2007, 11:52 PM
Lambchop
PF Idiot Sniper
Lambchop's Avatar
Problems already eh? nice one
Old 29-04-2007, 12:02 AM
Physio
Physio's Avatar
Yes Steve
NUTS RuS longer screw in the metering unit?
Old 29-04-2007, 12:04 AM
Lambchop
PF Idiot Sniper
Lambchop's Avatar
Look on the bright side mate!! This car is going to save you money in the long run! You arent gonna want to sell the evo anymore and lose money buying something else before realising evo's are best and having to buy another!
Old 29-04-2007, 12:12 AM
Physio
Physio's Avatar
You could well be right geeza
Old 29-04-2007, 12:24 AM
gary scott
gary scott's Avatar
Try turning the screw down on the left hand side of the throttle body?? The one that puts tension on the cable.
Old 29-04-2007, 12:34 AM
Physio
Physio's Avatar
Tried that too
Old 29-04-2007, 08:53 AM
Jim Galbally
Jim Galbally's Avatar
ah, so you've got a nice airleak somwhere, and the idle mixture screw's been wound right in to put enough fuel in to stop it stalling
start spraying stuff near bits that leak
and without trying to cause offence to Roosie... check everything's connected up the way it should be, dumpvalves, bleedvalvles, actuators etc.
Old 29-04-2007, 08:57 AM
NUTS RuS
NUTS RuS's Avatar
Originally Posted by AJ THE PF GOD
Yes Steve
Cant believe you fell for it
Physio
Physio's Avatar
I'll have a look today to see if i can find a leak anywhere, it rev's high even with the mixture screw taken out
Old 29-04-2007, 08:58 AM
Physio
Physio's Avatar
Yes Steve
When you push the flap down slightly in the metering unit the rev's do drop down so i thought you was being serious
Old 29-04-2007, 09:02 AM
Roosie
500bhp Cosworth in making
Roosie's Avatar
think you might find the servo might be leaking were that shitty joint it.
there is no bleed valve and has a new pipe on actuator to turbo.
Jay,
Sponsor
Jay,'s Avatar
dont rst's stall if theres a air leak on the boost system ?
Old 29-04-2007, 09:06 AM
Jim Galbally
jay, not if you put the fuel in to match.
the screw on the metering unit lifts the flap up more (or down, cant remember which way it is on KE) in its rest position, making it add more fuel
it could have an iffy metering unit, take it off and make sure all the moving bits move freely, and spray SHEDLOADS of wd40 on anything that doesnt move like it should
Old 29-04-2007, 09:10 AM
mk2rstaff
mk2rstaff's Avatar
must be an aqir leak that, try spraying colld start around the inlet and see if it changes the revs any
Physio
Physio's Avatar
So if the flap in the metering unit is pushed down that add's more air & less fuel?
Old 29-04-2007, 09:12 AM
Ginge !
just finding my feet
Ginge !'s Avatar
spray brake cleaner around places and see if the revs rise, when it doe then thats where the air leak is
exactly as jim says apart from dont spray the car with wd40,, brake cleane evaoporates and wd40 with stay there atracting all sorts of dirt/grease and shite and you will NEVER clean it all off
good luck
Old 29-04-2007, 09:13 AM
Jim Galbally
flap gets sucked down to add more fuel
Old 29-04-2007, 09:14 AM
Physio
Physio's Avatar
I better get down to Halfrauds & get some brake cleaner or cold start - whats gonna do a better job?
Old 29-04-2007, 09:16 AM
mk2rstaff
mk2rstaff's Avatar
cold start mate it just evaporates away, but mind not to use to much engines can get seriously addicted to it
Ginge !
Ginge !'s Avatar
aj the both do the same, we use brake cleaner at work as we got fucking boxes of the stuff and its 50p a can
it evaporates and makes the revs rise when spraying the engine bay,,,, oh and also helps to clean the engine bay aswell and blows out dust ect
so IMO use brake cleaner,,,, but that is just my opinion based on my experience
Old 29-04-2007, 09:17 AM
Physio
Physio's Avatar
But when i push the flap down (open) the rev's drop down
Old 29-04-2007, 09:20 AM
Ginge !
Ginge !'s Avatar
aj have you ever thought about buying a reliable jap car ????
this is the reason why i ALWAYS recomend a efi conversion
check the breather pipes theres a t peice near the metering head that comes undone and what happens is you get a anti lag effect when you change gear,,, people adjust shite to hide the bad running rather than spot that fault
i hear evos are decent cars
Jim Galbally
thats because it'll be overfueling when you push it down too far
the amount of movement you need on the flap is TINY
i'd deffo be checking for an air leak... oh, and check the timing whilst youre there, it might be too far advanced to try and cover the airleak too
Old 29-04-2007, 09:22 AM
Physio
Physio's Avatar
Anyone want to buy an S1?
Old 29-04-2007, 09:23 AM
Jim Galbally
seriously aj, if you cant find the problem, get it down your local bosch specialist, there are loads of em out there.
just gotta find one, who hasn't forgotten how mechanical injection works
mk2rstaff
mk2rstaff's Avatar
never raced or rallied one careful owner
Ginge !
Ginge !'s Avatar
erm jim,,,,,, you HAVE met aj havent you
HOW THE FUCK IS HE GONNA BE ABLE TO CHECK THE TIMING
hes not a car mechanic so doubt hes gonna have a danny how to check and asjut the timing on a mfi car,,,, theres techs at my work who dont know how to do that
aj be carefull when pressing in that flap,,, dont want you getting sucked into the engine
Old 29-04-2007, 09:26 AM
Physio
Physio's Avatar
ROFL
Ok so where do i start?
Do i get a can of petrol first & then a box of matches or the other way round?
Old 29-04-2007, 09:29 AM
Jay,
Sponsor
Jay,'s Avatar
petrols good
ginge is right brake clean and check all fitted hoses remove and blank the wank valve if it aint that then it might need the metering head serviced
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
just leave it
Old 29-04-2007, 09:31 AM
Ginge !
Ginge !'s Avatar
EBAY IT
can i have the coment of " ginge is right" framed please
Stu.H
Stu.H's Avatar
AJ, Im sure someone said it was running massively rich?
Would this affect it?
Old 29-04-2007, 09:32 AM
Physio
Physio's Avatar
I thought it would but i've messed with the mixture screw in the metering unit & it doesnt make any difference
Old 29-04-2007, 09:33 AM
Jay,
Sponsor
Jay,'s Avatar
er no coz we think that you have been possed by chip at this very moment and that normal service will resume
Old 29-04-2007, 09:34 AM
Ginge !
Ginge !'s Avatar
if its running rich it would rev higher as such,,, more likley stall due to flooding
have you tried to convert it to cossie management
Quick Reply: Revving high question *UPDATED*
