what headgasket, cant afford wire rung block
blown my turbo up so think im gonna go the T34 route n greys
but think i best change my headgasket as well cos that int gonna last much longer
whats the best headgasket to go for?
karl advised me on wire rung block but i cant afford it
Originally Posted by The Diva
YBO 611 group A gasket and standard bolts......fitted correctly will be more than adequate for what you want mate... ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![](https://img.photobucket.com/albums/0803/stirling/Engine%20and%20Tech%20Pics/zzzzzzzzzhg2.jpg)
![](https://img.photobucket.com/albums/0803/stirling/Engine%20and%20Tech%20Pics/zzzzzzzzzhg1.jpg)
I`ve heard of keeping spares,but isn`t five a bit paranoid....
Doug.....I`ve heard of keeping spares,but isn`t five a bit paranoid....
Anyway you'd be paranoid too if you KNEW everybody was out to get ya
Originally Posted by Lambchop
I've heard that before about the last esc cos gasket being better than GpA. So are they available from Ford?
quality cheers lads
think i'll go for dougs recommendation at £35 bargain!
and that will fit my green top fine will it? do i need to buy owt else in? best fitting new bolts?
Originally Posted by T28 RST
How much is it costing to get the block wire rung
I paid £100 about 4 years ago for mine![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
PF Idiot Sniper
Cawood 4 years of inflation
nah someone just wrapped a load of chicken wire round your block, charged u £100 n told u it was wire rung, u'd never notice the difference mr cheque book!!
Victor reinz who make BOTH the ones mentioned YBO1261 + YBO 611 use a far superior material for the latter ie YBO611 is better, maybe why they charge more???
They also make a SINGLE PIECE STEEL!!
oh dear. I'm confused now too. Just bought a grp a one, but if the escos is better, i might stick that in instead. Do all the holes line up though?
Why would the group A one be more expensive then? apart from being "group A"
The late spec Es Cos ones (1261) used to be available from your local Ford dealer for under £ 20.00
Is saving £30 odd pounds worth the hassle of doing the job again ?
When the cossies were being developed, there was shown a weakness in the gasket material, so better ones were made, and are the same ones as used for group a, lots went back under warranty, replacements were ALWAYS group a.
It is your money you decide.
Originally Posted by Daviet
Originally Posted by CossieRich
Cometic multi-layer gasket. Thats what i use on mine ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Originally Posted by JayCos
ive run a 611 on mine on a t34 .63 runing 34psi and 30 to 7k for 6000miles hard miles learning to map ect thrashing the titts out of the engine and the head off and the gasket was mint not a mark so thats what i have brought to put back on
Group "A" may be more money but gets my vote over the later Escos one as the Escos one WILL rot away in time just like the standard gaskets used to do as they maintains albit a slightly better design but the metal rings in the corners ARE a BIG factor when it comes to big boost!
ps m8 had his block wire wrung in situe once head was off of course and was only charged £25 a cylinder and that was with having the wire fitted also
