yellow injectors
bosch 0280150718 does any one know the bhp or flow rating of these as ive been offered a set for my fiesta turbo,also which greens will fit a fiesta dark or light
Forget the injectors, if they are cossie ones and you are using standard
managment EEC4 , they WONT work.
You can ONLY use High impedance type as the cossie ones are low impedance.
You will damage the ecu if you do
You have to use the exact injectors for the correct chip otherwise you
will be in trouble.
Unless your engine and turbo are capable of making more power than
the beiges allow then you will need a set of high impedance injectors
and possibly a custom live map.
will be in trouble.
SOME, ECU's can cope with the earlier type of 3 ohm as opposed to later 15 ohm if they have a resistor in the earth line to prevent the driver from overheating, but much easier to get correct ones.
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
