Running AFR gauge as well as Closed Loop
Old 23-04-2007, 06:20 PM
Jasesapphy
Jasesapphy's Avatar
Default Running AFR gauge as well as Closed Loop
Is it ok to do this off the same sensoe or does it need to be seperate
Many Thanks
Old 23-04-2007, 06:34 PM
Rick
Rick's Avatar
Depends on the sensor/management. If you on L/P8 - then it is a narrow band sensor, so won't work with a proper wideband gauge.
dombanks
21-09-2015 08:38 PM
Marino
12-09-2015 11:10 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
CrOwSoN15
14
03-09-2015 12:21 PM
Quick Reply: Running AFR gauge as well as Closed Loop
