Do bigger wheels make your car slower?
Depends what you mean by slower?
Acceleration may be slower, but cornering may be faster due to lower profile tyres with stiffer sidewalls.
Weight plays a factor - something like a Volk Racing CE28N can weigh ca. 5.5kg in 15" much less than a standard cast alloy wheel in 14".
Originally Posted by s1rststeve
i am sure it does, where i live there are loads of corsas and 106s with big wheels which sound like they are going fast but are slow as fook!!!
i had pepperpots on mine for ages went back to 12" pranwheel steels for the MOT and left them on
2kg lighter a wheel inch less diameter loads better accel
Originally Posted by Gary_R
Bigger alloys mean more weight, whether or not its noticeably difference I don't know.
Depends on the OVERALL weight of the wheel tyre combo, where the weight is!!, and overall diametre, a combination of all three.
If the wheel is heavier it could still be better as it may be that the lower profile tyre is lighter thereby moving mass towards the centre of the hub if you see what I mean, ie if the heavier weight is nearer the centre it will accelerate better than one of the same weight that is heavier on the outside of the wheel, as wheel acts as a lever.
Lighter wheels really do make a hell of a difference but not as much as some say, a man on thursday evening at snetterton told me how his road going porsche does 228mph on 450bhp "because he has lighter wheels".
in a nutshell,if you increase the overall diameter it will slow your accelaration and give you a higher top speed.its all do do with gear ratio.it also puts your speedo out.
also it will only increase top end if you have a shit load of power, i.e. enough to get to the limiter in top gear. otherwise it will just make the sameish top speed but at a lower rpm as the engine will run out of power to push it faster.
here,s a pic of the wieght of my volks TE37 there 520kg sorry for the quality but you can just make the weight out
im just in the process of swapping them for some new 17in but there realy light
andy
andy
PassionFords Creator
Everyone seems to have missed teh fact that if you fit bigger wheels you then change teh tyre size so that teh overall rollimg circumference is exactly teh same.
So, if teh wheels you fit were the same weight, then no you wouldnt affect teh speed of your car at all.
Testing the future
depends where the weight is carried stu as it could increase the inertia and slow acceleration (like a heavier flywheel) - in theory
i can't see it making much difference on a vehicle weighing over a ton though
Originally Posted by Stu @ M Developments
Everyone seems to have missed the fact that if you fit bigger wheels you then change the tyre size so that the overall rollimg circumference is exactly the same.
So, if the wheels you fit were the same weight, then no you wouldnt affect the speed of your car at all.
depends where the weight is carried Stu as it could increase the inertia and slow acceleration (like a heavier flywheel) - in theory
he thinks its the best move he has ever done to his race car
I fitted bigger wheels and then changed the tyre to the smallest diammeter I could get to increase acceleration. (over 1" smaller diammeter and I can live with the lost 2 or so mph)
I am amazed at that if its a heavy car and therfore stand corrected.
You personally would have got a very similar effect by changing teh differential ratio and teh topics not about that either.
Perhaps CabbyRS can give us some before and after sizes of both wheel and tyre.
But, in a nutshell, the answer is probably no, not as much as you'd really notice.
Testing the future
what do you think about the flywheel then gareth? can that have a noticeable difference? there's even aluminium FEAD pulleys available that have claims of increased acceleration
The radius of the wheel has more impact than the weight. Generally when people go up a size (as pointed out by stu) the tyre comes down so you normally end up with the same radius.
It's all to do with angular momentum and the moment of inertia which is wheel mass * radius^2 as the radius is a squared it has more effect. In simple terms the bigger the radius the more torque is required to get the wheel spinning so a smaller radius wheel would take less.
as far as i know stu they was very close,,,,
he got different diff ratios, so its not like he cant gear it the same also
im not really too sure about flywheels as to how the engine would accurate under load,,, ofcause off load it makes a massive difference
Testing the future
of course off load. maybe some noticeable effect in lower gears, but not in higher ones
but with wheels, the gearing also affects the inertia that the engine sees, so could be quite noticeable thinking about it.
also, a heavier wheel is not good for the suspension as the unsprung weight increases and tends towards the sprung weight.
not to mention the gyroscopic effect of larger wheels making them more reluctant to change direction.
all of that is why you should only use wheels that are big enough to cover the brakes that you need and no bigger - whereas most people these days fit big wheels cos they 'look better' and then buy big brakes to fill the wheels increasing the unsprung weight further
on the flip side there is a reason why tourcars run big wheels,,, and its not the brakes
they can control tyre temps alot better,,,, and wear rates because of larger area
lockie
31-07-2015 10:03 PM
