How does capacity affect BHP?
Old Apr 26, 2007 | 03:05 PM
  #81
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Im not talking about maximum power Stavros....
All i said was that an increase in capcity should see you with an increase in power of the same amount.
Various people posted saying I was wrong and that you very rarely see any increase in power.
Karl even stated that he has bolted a 1.8 bottom end on instaed of a 1.6 and got no extra power.
he must have missed something as power should have jumped over 10 bhp just by changing the bottom end.
I have not read the whole thread but I think I can see where you are coming from... e.g.
If I had a 1600cc K series lump and swapped the bottom end over for an 1800cc version using the complete 1.6 head the power would rise from 111hp to 118 (as long as a suitable map is used) BUT if the 1600 engine's head was flowing the most it could already then changing the capacity is not going to increase the power.
Old Apr 26, 2007 | 03:08 PM
  #82
RichardPON's Avatar
RichardPON
Im not talking about engines that are restricted by some factor Im talking about a normal engine.
Surely ALL engines are theoretically restricted by some factor?
Old Apr 26, 2007 | 03:12 PM
  #83
rapidcossie's Avatar
rapidcossie
Originally Posted by Stu @ M Developments
I think everyone is arguing for different scenarios now.
Maybe someone should do a summary... Hows this.
IF you design an engine that achieve a given volumetric efficiency (say 85%) at a given RPM it will make X power.
If you then change its capacity, but redesign the engine itself to allow it to still meet the same VE and RPM statistics as the first engine, you WILL make more power.
the engines are not redesigned on the example im using Stu.
If there is a restrition like a carb that is stopping the engine flow more air then I agree that no matter what you do the power will not increase.
if there is no restrction then power WILL go up.
Old Apr 26, 2007 | 03:20 PM
  #84
RichardPON's Avatar
RichardPON
But surely Karl's proven that isn't the case by putting that 1800 bottom end together with the rest of the engine and NOT seen a power increase.
Old Apr 26, 2007 | 03:21 PM
  #85
AlexF's Avatar
AlexF
Yes it will
but not in a linear way
Old Apr 26, 2007 | 03:22 PM
  #86
rapidcossie
Yes it will
Did you not see my post with the details of the OHC engines?
it looks linear to me.
Old Apr 26, 2007 | 03:25 PM
  #87
RichardPON's Avatar
RichardPON
Euan - those OHC engines. The heads, cams etc are all identical on each one?
Old Apr 26, 2007 | 03:26 PM
  #88
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Euan,
It probably goes up in a reasonably linear way for the OHC engines, as they are not maxed out to their absolute limit in the first place. If they WERE, then I would assume that although there would be an increase, it would get smaller and smaller with capacity rises UNLESS the capacity increase was gained with more cylinders (and therefore more valve area etc).
Old Apr 26, 2007 | 03:30 PM
  #89
rapidcossie
Euan,
Your 100 % right Mike.
Old Apr 26, 2007 | 03:31 PM
  #90
Mike Rainbird
Caraholic
Of course I am . I taught Alan EVERYTHING he doesn't know .
Old Apr 26, 2007 | 03:32 PM
  #91
AlexF's Avatar
AlexF
so pintos from
1.6
1.8
2.0
yes?
Alex
Old Apr 26, 2007 | 03:35 PM
  #92
RichardPON's Avatar
RichardPON
Euan - did you see my genuine questions, or does someone have to a 500bhp+ cossie to get an answer to a simple question?
  #93
rapidcossie
They increase in a linear fashion dont they alex...
Old Apr 26, 2007 | 03:38 PM
  #94
rapidcossie
As far as i know they are mate.
all pintos heads are the same.
Old Apr 26, 2007 | 03:41 PM
  #95
rapidcossie
Mike is the only person i have replied to that has a 500 bhp cossie
Old Apr 26, 2007 | 03:42 PM
  #96
Martin-Hadland
I dont think the cams are the same.
1.4/1.6/1.8 K series 16V engines all use the same head,cams etc except VVC/135 engines.
Old Apr 26, 2007 | 03:44 PM
  #97
rapidcossie
Take it the power increases untiil the head cant flow anymore martin?
Old Apr 26, 2007 | 04:09 PM
  #98
AlexF's Avatar
AlexF
I don't know - I don't work on pintos... I was about to ask what the HP outputs are....
But I remember reading the cams are different - but no proof etc etc.
Alex
Old Apr 26, 2007 | 04:13 PM
  #99
rapidcossie
who mentioned Alan
Old Apr 26, 2007 | 04:16 PM
  #100
Stu @ M Developments's Avatar
PassionFords Creator
I staed that a 25% increase in capacity will see you a 25 % increase in power...
I got shot down in flames for stating this even tho i know it to be true.
So tell me then, since your 100% right and certain the rest of us are talking nonsense... if the Cylinder head you bolt this new capacity bottom end onto cannot flow 25% more air than it did previous. Where is your extra power being made and how was it achieved?
Old Apr 26, 2007 | 04:41 PM
  #102
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
What an interesting discussion.
Old Apr 26, 2007 | 04:45 PM
  #103
foreigneRS's Avatar
foreigneRS
Testing the future
half the time the power that a production engine has is nothing like what it could have anyway - it's limited for marketing reasons
Old Apr 26, 2007 | 05:38 PM
  #104
Lee Reynolds's Avatar
Lee Reynolds
I understand all this But, why do manufacturers like ford sell bigger engined cars then? Whats the point to them?
Ie why sell a focus with the choice of 1.6, 1.8 and 2.0 litre engines?
Why not all be 1.6 with the choice of 1.6 std, 1.6 bigger air flow, 1.6 even bigger air flow...???
Gen question...
Old Apr 26, 2007 | 05:43 PM
  #105
GARETH T's Avatar
GARETH T
i think that comes down the marketing again lee
Old Apr 26, 2007 | 05:46 PM
  #106
ECU Monitor Enthusiast
GARETH,
Its all down to emmisions and fuel economy
Old Apr 26, 2007 | 06:15 PM
  #108
Gen question...
For NASP engines, Low end torque mainly.
Old Apr 26, 2007 | 06:16 PM
  #109
Lee Reynolds
i see
Not something ive ever sat down and thought about TBH.
Nice thread to read
Old Apr 26, 2007 | 06:31 PM
  #110
rapidcossie
I did not state that you will get your increase in ALL cases.
The engine I originally commented on was my friends subaru EJ20 which is known for having big valves anyway.
He bolted on an EJ25 bottom end and got a 25% increase in power.
This is all I commented on but was told this HAD to be un true due to these laws and ideas people had.
I said I had wittnessed with my own eyes so I knew it to be true.
I then provided other examples where this is also true.
I dont claim to be an expert or do I claim to be 100% correct but I did claim that these increases where achiveable where other said thy were not.
Old Apr 26, 2007 | 06:33 PM
  #111
rapidcossie
Originally Posted by Matt J
So in a round-a-bout way Euan you've ended up saying the same as karl?
Those OHC examples you gave, if its the same head etc on them all then its obvious that the heads nowhere near its flow limit, so all ford did was swap the bottom ends and fit a different carb (assuming the carbs are different) this would give the increase would it not?
In which case it wasnt really the capacity change that increased power it was the that the head could flow enough power in the first place.
I'm sure if the head was designed for max flow on the smallest capacity engine the power wouldnt go up if you bolted on the biggest capacity bottom end would it?
Its getting complicated now
I understand fully what your saying Matt, sorry but Im no expert(get out clause )
Old Apr 26, 2007 | 06:34 PM
  #112
GARETH T's Avatar
GARETH T
court adjourned
Old Apr 26, 2007 | 06:37 PM
  #113
rapidcossie
For now
Old Apr 26, 2007 | 06:48 PM
  #115
Jim Galbally's Avatar
Jim Galbally
hold on, so you told all the experts that they were wrong, then you agreed with them?
i woulda thought you'd have stopped after people mentioned the F1 engines being 1.5 litre instantly rubbishes any capacity theories
Old Apr 26, 2007 | 07:09 PM
  #116
rapidcossie
I dont agree with them Jim....
I can see where they are coming from but we are actually arguing about two different points.
So it cant go anywhere.
Old Apr 26, 2007 | 07:35 PM
  #117
Lambchop's Avatar
Lambchop
PF Idiot Sniper
It depends how big your dad's are really!
Old Apr 26, 2007 | 07:54 PM
  #118
Jim Galbally
[edited because i sounded like an argumentative cnut]
either you're right, or the highly skilled professional reputable engine builders are
  #119
I think this shows that everyone is arguing about different things and are all correct in their own way. To finalise my thought on why you cant just increase capacity and gain great power;
If you had taken that scoob to 3.0 litres and gained 50% more power, do you hionestly think that then boring it to 6 litres will actually double it? Thats what your posts have suggested you think, hich is why everyone is debating it...
Some engines are capped miles away from their flow limits and some are damn close to it indeed. And this topic, incidentally, was about Turbocharged engines not NASP, and i dont care how big you bore out teh YB, a 4litre standard YB with a T4 on will NOT make 1100BHP no matter what your friends say.
Old Apr 26, 2007 | 07:56 PM
  #120
Jim Galbally
and the reason you gained that power, wasn't because of the increase in capacity.. lol
thats the bit you're missing, cause and effect
