ofab engine loom
Old Apr 13, 2007 | 08:26 PM
Cowboi's Avatar
Cowboi
Default ofab engine loom
what needs connecting and to what to get the engine running???
ie live, switched live, neg, taco etc
any ideas what any of the wires on the loom are for??
need to start connecting the loom up in my mates mk3 escort that started life as a carb
a wiring diagram would be great if anyone has one and i should be able to work it out from there
Old Apr 13, 2007 | 08:28 PM
Ginge !'s Avatar
Ginge !
just finding my feet
arghhhhhh
ive got the fucking information for him,, do you lot NEVER speak or something
its piss easy and ill be round yours when i finish up some other business
Old Apr 13, 2007 | 08:45 PM
Cowboi's Avatar
Cowboi
half the reason i posted is coz i knew u was on and would read it!
im at work all weekend.
pass the info on if u can mate.
ive gotta get my nova sorted before i do pauls car.
but seeing as im an electrician and wired my nova i guess i should do it for him
just need to know what wires do what, i should be able to find them on his escort.
if not that will be the next post
Old Apr 13, 2007 | 08:46 PM
Cowboi's Avatar
Cowboi
btw i stripped the loom down and found there aint many wires to connect really.
just donno whats what tbh
Old Apr 13, 2007 | 08:53 PM
Ginge !'s Avatar
Ginge !
the green one is for the clocks,,, he will NEED the cabrios rev counter as hes on coil pack
the other colours ive got the info but its secret info
Old Apr 13, 2007 | 08:54 PM
Ginge !'s Avatar
Ginge !
the escort loom he will need to keep the thermostat switch.oil presure, temp sender wire but he should keep ALL the loom intact and then use the ofab loom as a sub loom
he also needs to do the pin swops like we did before too !
Old Apr 13, 2007 | 09:01 PM
Cowboi's Avatar
Cowboi
why will he need to do a pin swop?
he is using an ofab loom, with an ofab ecu, with an ofab engine.
the oil temp, pressure etc will just go straight onto the frst engine from his existing loom im guess.
he is convinced he needs to go back to the fuse board.
i've tried telling him he just needs to connect in the ofab loom but dunno if he got it.
pop round of email me the info and we'll get him up and running hopefully.
he was out there today looking for cables the same colour on his car as he has on the loom, but couldnt find any.
Old Apr 14, 2007 | 09:56 PM
rst in breaking's Avatar
rst in breaking
i know i dont have to go to the fuse board but iwas hoping some wires would match but no such luck, could i use s1 clocks? need to try and get it wired up 2mo and running to have any chance of taking central day, got to make other bracket up for brake caliper, more brackets on exhaust, fit rad (need one first) fit cooler and fans, change fuel tank and loom and run hoses and got feeling il have to change rear bushes as they'r perished
Old Apr 15, 2007 | 07:38 PM
rst in breaking
has anyone got this info please as im running out of time for central day and need car running and m.o.t'd asap? if nobody has info, how much should i be looking to pay and auto electrician to do it? cheers
Old Apr 15, 2007 | 10:04 PM
Ginge !'s Avatar
Ginge !
1, Red -- +ve
3, Brown/Yellow – octane / idle adjust
4, Brown/White – speed sensor
7, Brown/Green – engine temperature sender
16, Brown – current return & 40
17, Brown/Green – diagnostics connector
20, Brown – current return
21, Brown/Yellow – idle speed valve
22, Brown – fuel pump relay
23, Brown/Red – octane / idle adjust
24, Brown/Blue – octane / idle adjust
25, Brown/Yellow – air temp sensor
26, Brown/Black – throttle sensor & co adjust pot & map sensor
27, Brown – CO adjust potentiometer
28, Blue/Yellow – Pin 2 on edis (disconnected)
33, Brown/Green – Boost control valve
36, Blue/Red – Pin 3 on edis
37, Black – idle speed valve & injectors & Speed sensor & Boost control (tbc) & 57
40, Brown – current return & 16
45, Brown/Yellow – map sensor
46, Brown – map sensor & engine temp & air temp & throttle & CO adjust
47, Brown/Green – throttle sensor
48, Blue/Green – diagnostic connector
56, Blue/Yellow – Pin 1 on edis
57, Black – idle speed valve & injectors & Speed sensor & Boost control (tbc) & 37
58, Brown – Injectors
59, Brown – Injectors
60, Brown – current return
oh and you HAVE to use efi rev counter as you have got a wasted spark ignition system
sorry i aint spoke to you today but i had a hangover from hell this morning and you calling me every 20 mins when i was trying to sleep it off made me a right grumpy fucker and i never got over it till 6ish
but tbh paul you aint gonna get it running and mot'ed ect for central day as you got alot of trial and error stuff comming up and theres gonna be a few things you aint thought of that still needs doing
Old Apr 15, 2007 | 11:21 PM
rst in breaking
its poss, i have to mount tank back up, fit rad, cooler and plumb hoses and as for wiring il sort you out if u fancy wiring it?
big_Rad
Sep 15, 2017 09:36 AM
Marcus L
Aug 29, 2015 02:18 PM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
