Is it possible to sleeve the small end of forged con rods?
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Basically i've got a set of forged pistons with 19mm gudgeon pins and i've found a set of forged rods that are shorter than any others and will give me the compression ratio i'm after.
However - the little end of the rod is 13/16" which is 20.6375mm - is it possible to either machine the piston to accept the larger gudgeon pin or to fit a sleeve into the little end of the con rod and then machine it to 19mm and use the original pin and piston?
Football Cwazy
have you measured the little end bush yet? i know they need reaming to fit the pin properly, although i doubt there is quite that much meat to start with.....maybe you could find a company who manufactures the little ends and have some made especially. ??
Originally Posted by Stavros
Ring Will at RC Developments, he should know
sorry, but i like that joke![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
And anyway - i'm offf work at the moment recovering from surgery so can't ask all these questions there
DEYTUKURJERBS
PS, you get thanked in, erm, some jap mag (forget which) feature on a white late shape evo that RC tuned
If there is enoguh meat on the roids they can be taken out then brought back to size, a sleeve of anythung ar ound a mm is not going to work, I would be very surprised if there was not enough meat though to have this done.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
