Rust prevention on Steel submersed in water? Electroplating?
Does anybody know a way to protect a steel component that is continually submersed in water from rusting???
Ive looked at Zinc electroplating but was told it may only last a year before the Zinc gives up to the steel.
Suggested that I might try Nickel, but before I do I thought i'd ask here since I know some people on here experience of this sort of stuff.
Any advice for what might work???
Thanks to ALL for the replies
I tried but its killing all my tooling
Just normal water (possibly with methanol added).
Its essentially the same as a Bulkhead adaptor for a Tank outlet.
Or put another way, its like an M16 set screw, with a 1/4 BSP hole through the middle.
Tank has a hole on the bottom, the adaptor pushes through the hole, then a dowty washer is pushed onto the external thread and a nut screwed on to hold it in place. Then a 1/4 BSP hose Elbow adaptor (a bit like the 3rd one in the pic) is screwed into the internal thread.
Mainly static only movement is due to gravity.
Its the outlet for my Water Injection tank.
The outlet I have now is Zinc coated steel, and has started rusting.
Ive tried to find one in Aluminium but unsuccessfully :-(
Would this work??? I can get it powder coated for nothing (family member).........
Just for clarification here's a quick drawing of what it is............
The bottom of the 4 shown on the left is what I have but not in SS but normal steel.
I also had the upper face machined (the top that is inside the tank) to a lower profile, with ramped edges and slots for easier water passage out.
Originally Posted by Electronic
Make it from stainless steel.
Originally Posted by tabetha
What water is it, SALTWATER or just normal water ?
What is the temp of the water ?
Originally Posted by Big Will 85
What sort of size are we talking about mate?
What sort of conditions will it be exposed to - will it be static water or moving etc.
Originally Posted by GARETH T
powdercoating?
Originally Posted by Cowboi
worth maybe checking a local plumbing shop incase they sell something similar in plastic??
Ive heard they can be found in brass too..........
by the sounds of it you seam to have access to machines. if you could get a lump of plastic and machine it down to 16mm and drill a hole through it, and put your shoulder on it etc you could probably source a bsp tap somewhere.
good luck with it
good luck with it
Stainless is hard i will say that, are you using plenty of metal cutting fluid while trying to turn it etc and correct speed settings? Or is it the tapping part thats the hard bit? If you really are struggling go to a machine shop and they will do it for you i had a couple of sump plugs made for fitting an oil temp sender purely because i didnt have the right tap. When i went to pick them up they gave them to me free of charge!
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Originally Posted by THEYGOTMETO
What tooling are you using? What DOC and feeds are you using? I've always found Stainless (depending on the grade) reasonably easy to machine, although I know some people totally hate working with it because it work hardens quite easily.
I can probably answer both of these in one.........
I have a very old manual lathe with limited tools, and plenty of free play in the threads
But it was free and is plenty good enough for the Aluminium parts i've turned.
Just nowhere upto the job of doing SS.
If you really are struggling go to a machine shop and they will do it for you i had a couple of sump plugs made for fitting an oil temp sender purely because i didnt have the right tap. When i went to pick them up they gave them to me free of charge! Mort de rire
Charming!!!
I might have to wait until I travel a bit further away and see if there are any other machine shops that might be able to help, unless I can get a waterproof coating of some kind for this one..........
Originally Posted by richm
just an aside, but would you be better having the dowty washer inside, between the fitting and the tank? There is the potential to leak past the threads inside the nut as is..
The tank is not that big and so I need to utilise what volume I have.
I had loads of PTFE on the threads too............
Well............
I think I may have found something to try
RS components 458-6823
Is SS, and has an internal 1/4 BSP and external thread of 20.5mm.
Might be ok, what would be better Brass or SS??? the SS is about twice as much.........
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
