Help - Removing Badges
Old 15-09-2004 | 03:38 PM
Skiman's Avatar
Skiman
Default Help - Removing Badges
Ive new badges for my escort cosworth as the old ones are a bit tatty but i cant get the old one off, ive tried boiling water but it didnt work, any ideas?
Old 15-09-2004 | 03:43 PM
Sticky.'s Avatar
Sticky.
Get some thin wire & run it up & down behind the badge, then just wipe the black foam (glue) off with your finger.
Old 15-09-2004 | 03:44 PM
Paddy's Avatar
Paddy
Legend
Boil the water again, make sure you've got any bits of plastic trim covered with a rag else you'll muck it up...
Get one of those scrapers for wallpaper, rap a rag round it so you don't scratch the paint and when the glue is still hot, slide it down the back
Old 15-09-2004 | 03:47 PM
soulweavers's Avatar
soulweavers
This will sound silly, but it works, use a hair dryer to soften glue, once badges are off use white spirit or turpentine to remove any remaining glue, wash area with soap and dry, thats it. Note keep hair dryer moving so not to bubble the paint.
Old 15-09-2004 | 03:49 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I removed mine with a hair dryer and they just pulled off by hand - just heat them up and pull a bit away at a time - the difficult bit is getting it started, once you have it comes off easily. The glue residue just polishes off - job done .
Old 15-09-2004 | 03:50 PM
Paddy's Avatar
Paddy
Legend
This could work, tie one end of a big rope to a tree, the other end to the badge [you may need to take the badge off first to get the rope round it], then drive off really fast.
Remember to T-Cut [or whatever rubbing compound you got] then polish.
Bake for 45 mins at gas mark 12.
I need a nap.
Old 15-09-2004 | 03:52 PM
Sticky.'s Avatar
Sticky.
Best glue remover is UPVC cleaner, smells like pear drops but does the trick & doesn't damage the paint
Old 15-09-2004 | 05:07 PM
ballin's Avatar
ballin
use a hair dryer, works a treat
Old 15-09-2004 | 05:22 PM
whitneyd's Avatar
whitneyd
I used fishing string with a up and down motion
Old 15-09-2004 | 11:34 PM
Skiman's Avatar
Skiman
nicely described there whitneyd lol....
Old 15-09-2004 | 11:40 PM
Thrush's Avatar
Thrush
Irritating c........
I did the rubbing strips on both sides of my 3i, and the boot Ford badge and XR3i badge using the hairdryer method and it does work fine
boeb
09-01-2020 06:11 AM
Orion_Gav
29-09-2015 05:50 PM
