Rear diff bearings.......
How big a job is it to change the bearings on a 4x4 7 inch Lsd please????????
Also how much play in the bearings is acceptable???????
Ta
Ta
Resident Wrestling Legend
driveshafts out
diff out
on the bench
updo the locking rings
undo the bearing rings
remove bearings with hammer
you will probably find that the diff will need to come out but this will be more work but it's only punching out the pins from the little gears inside and then stripping it out
knock the new bearings in and refit
ok, so i've made it sound really easy and i assume you it's not, mainly because there is a tool to remove the bearing holders otherwise you tend to span the little teeth off
diff out
on the bench
Hi Kev,
I was sent this link when i stripped my 2wd diff down.
http://www.fordscorpio.co.uk/manual/...ffOverhaul.pdf
It was ok to strip but the bearing housing were in very tight and were a bit of a pain to get out! It would most definately be much easier if you have the correct tools.
When mine was stripped i found all of the gears inside the diff were either badly worn or chipped
I did manage to get them new from Ford though
I got a guy at work to set the diff backlash/bearing etc for me.
Im pretty sure Marco would be your man to talk to if you dont fancy it yourself
Mart
Mart
Thanks for the help every1 ![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Cheers Marco,
I'll tell my m8,its going in a MK Indy kitcar,R1 powered
Hes only paid Ł25 for the diff from a local scrappy,its got a couple of mm play in the one output shaft on the diff,how much is acceptable m8????
Thanks Mart,that was what I was looking for,seen it on here before
Originally Posted by marco polo
hi kev
if you want it rebuilt i can get it re built for you , no problem
theres loads of options aswell , like uprated Viscous coupling -up prated planet gears
different ratios if needed no probs
marco
marco
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Originally Posted by Moonstone Mart
Hi Kev,
Mart
Mart
Cheers Marco,
Hes only paid Ł25 for the diff from a local scrappy,its got a couple of mm play in the one output shaft on the diff,how much is acceptable m8????![Top](https://passionford.com/forum/images/smilies/smile011.gif)
hi kev
marco
marco
hi martin
it's hard to tell without looking at it
so how much work is it to remove the diff???
i leave the rebuilding to the pros like marco
mines coming out soon, just deciding whether to get the garage to do it, or remove it myself
Quite heavy,don't drop it on your head
Torx bolts that hold driveshafts can be an arse
Just get a good quality torx socket,and clean all the years worth of shit out of the torx bolts before you try undoing them
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
