Fuse box smoking big time !!!!!!!!!!!!!!
Went out in the cos yesterday to get a few more miles on it and kept thinking I could smell something burning! I pulled over and lifted the bonnet and there was smoke coming frome the fuse box After inspection its the fan relay all burnt and the fuse box all melted Starting to get fed up with this bleeding car !!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by cos47
Ha Ha how did I know that one was coming
Originally Posted by charlie luciano
If its any consulation you're not alone, mines keeps melting the fucking loom under the steering colum, no idea why
Cossies are getting old now can't stop or beat the clock I guess
Luciano
Luciano
Too true mate I have already had to re-wire the fan fuse, looks like the relay is next
Me too had to re-wire the fan fuse also, I have also fitted the pro alloy fan conversion that runs less current so that the fan wiring don't get so hot
Poxy ford why didn't they fit a set up that's up to the job when they constructed these cars
Luciano
Luciano
1 Post
This is completely normal for sapphs, must be about 15 people i know so far.
Its not a major job , make a new fan loom, i have done it for mine, i used a seperate relay mounting behind the headlamp, takes power direct from battery, temp sender sends signal to switch relay.
My mate did the same but he put his to switch to earth, so the fan would continue running when engine was off, didnt really see a lot of point but thats what he did
Originally Posted by DazC
Let me guess, 2wd Sapphire?
Only cure is to fully rewire the cooling fan system and diconnect the old circuit from the fans.
Not good Lee, hope you get it sorted soon mate!
sridgett
18
01-08-2015 08:49 PM
