new map sensor.
Old Apr 8, 2007 | 11:53 AM
OrionRST200bhp's Avatar
OrionRST200bhp
Default new map sensor.
hi guys. yesterday i was doing a few things on my cossie replacing vacuum hoses etc and went to take off the hose on the map sensor and snapped the pipe on the sensor. is it worth getting a 3 bar map sensor or not? im running 280bhp. and can someone explain what the map sensor does? as im quite new to the cosworth engine,
Old Apr 8, 2007 | 11:57 AM
The Youth.'s Avatar
The Youth.
you have to fit the correct map sensor for the installed chip, ie if it's a standard map sensor you must replace it with one, good oppertunity to go to stg 3 using 803's and a 3 bar with a new chip tho!!
also when removing the pipe off the map sensor in future remove the pipe off the inlet then un bolt the map, and remove the pipe from the map on a bench, saves snapping them like most do!!
steve
Old Apr 8, 2007 | 12:20 PM
OrionRST200bhp
cheeRS mate, so what would happen if i was to fit a 3 bar map sensor to my setup now? would it just run like a bag of shite?
Old Apr 8, 2007 | 12:29 PM
The Youth.'s Avatar
The Youth.
yes or even worse you could bugger the engine, melting a piston etc..
steve
Old Apr 8, 2007 | 12:40 PM
gingeRS's Avatar
gingeRS
they always snap
Old Apr 8, 2007 | 12:50 PM
OrionRST200bhp
well i want to go stage 3 and i need a new map sensor so i may aswell get a 3 bar map sensor. so what else will i need to go stage 3?
Old Apr 8, 2007 | 01:07 PM
JonnyBravo's Avatar
JonnyBravo
You will need a suitable chip, a set of 803's (dark greens) and a -31 actuator.
Chips are available from plenty of tuners.
Stu @ MSD, Karl @ NMS or Ahmed Bayjoo are a few you could use
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
