Is there such a lead available to do this?
I want to connect my normal sky digital box to my HD tv via component but the sky box doesnt have any component holes in the back so i thought is there a lead i can buy thats scart on one end and component on the other end for my tv? (in a bid to get better pic quality)
you can set your sky box to run RGB out of the scart, and providing you use a good scart lead(£££) it'll be 99% as good as component.
component isn't actually RGB (although the leads are coloured Red/Green?blue) so can't just change it in the lead.
how big's your tv?
if it's <26" spend £30 on the scart (or more)
26"-32" £40-45
32"> £60-70
make sure your box is set to RGB, as the nice sky man usually doesn't!
how big's your tv?
26"-32" £40-45
32"> £60-70
Originally Posted by Zetec Andy
I changed mine to RGB and it looked worse so i changed it back!
You've got something wrong then - RGB is soooo much better.
If you had snow in the background when on RGB it's down to a combination of the composite signal still going through your cheap scart lead. You can cut a wire out of the lead to fix it.
If this snow is your problem, PM me, and I'll look up which one it was
Currently ive got a gold plated jvc scart lead to connect my sky box to my 32", but the picture isnt as clear as my old crt still.
Budweis, ive had the ps2 years, its just a red/yellow/white lead.
most of the gold leads you can buy are sh#t
jvc/philips etc are sh#t £5 scarts that are then gold plated
buy a monster/ixus or check some of the home cinema mags for ideas
all the gold does is stop the connection coroding, so when the lead is new, it makes no difference!
you'll find the better ones tend to be heavy and stiff, their shielding being better, and the shielding is kept away from the bundle of wires inside.
also, some of the better cables twist the pairs of wires together inside.
the idea being that if they are not running parallel they cannot interfere with each other inside the cable.
have you got a roof aerial plugged in
as ive had this in the past
pulled the aerial out and the pic was a lot better
Zetec Andy, Rob v
I'm sure this is the problem I'm talking about.
Set your sky to RGB then find a cheap scart lead and snap out pin 19 from one end and 20 from the other.
If you get no picture when you put it back, swap the 2 ends of the lead around, because I can't remember what way it had to go.
Please make sure you use a lead that you don't need in case something goes wrong
Let me know what you think...
Found some info:
http://www.answers.com/topic/scart
Quality differences exist in SCART cables. While a proper SCART cable would use miniature coax cables for the video signals, cheap SCART cables often use plain wires for all signals, resulting in a loss of image quality and greatly reducing the maximum cable length. A common problem is that a TV will output a composite video signal from its internal tuner, and this will be induced or cross-talk onto an incoming video signal due to inadequate or non-existent screening on a cheap SCART cable; the results will be ghostly images or shimmering superimposed on the incoming signal. To non-destructively verify if a SCART cable uses coax cables, one can unscrew the strain relief at the SCART connector and fold open the plastic shell.
Although using higher quality cables might help in reducing a 'ghosting' effect occurring, a more permanent method is to remove pin 19 from the SCART plug that is put into the TV. Pin 19 is Video Out, and removing it prevents a signal from being broadcast by the TV into the cable in the first place, so it cannot cross-talk with the incoming signal. Cheaper SCART plugs can sometimes have the pins pushed inside the connector housing so as to remove it in a non-destructive manner (and thus allowing for it's replacement in the future should the need arise by simply unscrewing the housing and pushing the pin back through its hole), though sometimes the pins are fixed in place on the inside by glue or rubber and can only be removed by forcefully twisting it off entirely. Generally though, for a standalone TV there is no need for video output on the TV end of the SCART plug, so in the majority of cases removing it completely shouldn't be a problem. Keep in mind though that whichever way it is done, once it is the SCART is rendered incapable of transmitting a video signal from that end of the cable, so it would be wise to mark it as such for future reference.
The Youth.
30-09-2015 09:59 PM
timsrs
22
24-09-2015 08:14 PM
