arrgghh fookin downloaded films subtitles
ok i know there free, but vertually every fookin film is in english etc but it has french or spanish subtitles
fookin does me head in
just downloaded that *********
the same
the same
if the subtitles are done properly using summink like vobSUB theyll have a seperate text file with the .avi with all the subtitles in it...
simply delete this file
et voila... the subtitles dissapear :P
dont work if the subtitles are actually part of the video frames tho
my apologies Petrucci
ok i have been told that while the films are stored on ya hard drive before writing you can remove the subtitles etc
what program does this?
like jimbob said otherwise if the subtitles are at the bottom out of the picture then:
1) Load the .AVI into VirtualDub (or one of its variants)
2) Set "Audio" to "Direct Stream Copying"
3) Set "Video" to "Full Processing Mode"
4) From under the "Video" dropdown menu, select "Compression" and select the same codec and settings that were used for the original .AVI
5) From under the "Video" dropdown menu, select "Filters"
6) Click on the "Add" radio button
7) Doubleclick on the "Null transform" filter
8) Click on the "Cropping" radio button
9) Enter the proper amount in the "Y2 offset" (at lower left) to cut off the subtitles
10) Click on "OK"
11) Click on the "Add" radio button
12) Doubleclick on the "Resize" filter
13) Under "New width and height" enter the NEW dimensions of your cropped video (e.g. 720x440)
14) Select "Precise bicubic"
15) Put a checkmark in "Expand frame and letterbox image"
16) Set "frame width" and "frame height" to the ORIGINAL dimensions (e.g. 720x480)
17) Click on "OK" (brings you back to primary "Filters" screen" and then click on "OK" (to get back to main VirtualDub screen)
18) From the "File" dropdown menu, select "Save AVI" and save with a NEW filename
10) Click on "OK"
i think i lost the plot by the 8th line
fook me how complicated does that sound
my m8 said somin along the lines of x copy div somin?
he said does it all for ya?
http://www.virtualdub.org/
hope it works mate, but the subtitles cant be in the picture cos basically this chops off the bottom where the subtitles are usually put (in the black bit) then puts it back minus the words.
i dont know any other way if they are etched in im afraid so thas it
ARRGGHHH fookin hell tried the above on two films no difference
evern more AAARRRGGHHH just got another latest one and the fooker is in some launitic language
this is fokin stupid every one i get either has subtitles or in wrong language
apples24
17
19-06-2004 03:29 PM
