Back pressure
Back pressure
Is there some rough guide what the exhaust back pressure should not exceed in Cosworth YB engine? I remember seeing somewhere that it should not be more than 25% bigger than boost pressure at peak power. Is this correct?
DEYTUKURJERBS
I take it you mean pre turbo, as post turbo you should just go for as little as possible.
IMO, PRE turbo, you shouldnt have a rule, as people get all obsessed with keeping the pressue down so go for crazy exhaust housings that makes the powerband shite.
You might not be getting all the power you could, but its about how well it drives for me.
I bet in a lot of common Cossie specs the backpressure before turbo is 250% what the boost is, never mind 25%
Im willing to bet that my cossie is the only one on here with no back pressure in the exhaust.
DEYTUKURJERBS
And thats believable depending on exhaust.
DEYTUKURJERBS
pre turbo back pressure im sure he means.
engines NEED backpressure to run right, turbos dont.
but many turbo cars run stupid amounts or pre turbo pressure, though for a good powerband it may be the best option.
i bet your motor has a ton of it, most road going big boost cossies prob do.
Yes, I meant before turbo, sorry for my confusing text I haven't measured the pressure from my new engine since it is still in pieces, but I will monitor 4ch egt's and back pressure when the engine is been tested.
Testing the future
simply because i understand physics and where you have a massflow you must have a pressure difference
think of it like this: in nature, how is the wind created? it's not from all those new white electric wind generators it's from the pressure difference between one place and another that causes the air to rush from the place of high pressure to the place of low pressure. just like water will always flow from high to low
DEYTUKURJERBS
Well thing is, different people reccomend different things, from a max of 25% more like you say, up to double the boost or more (IIRC ive seen 3times boost pressure on a number of cars).
The small exhaust housing may be restrictive as fook, BUT a bigger one will most likely reduce low down power, so its always a compromise.
I think its more effective (for drivabilitys sake anyhow) to just test the effects of different size exhaust housings if you think you want to improve on the original setup.
mrmann
20-08-2015 11:24 PM
Red_bull
09-08-2015 08:34 AM
