brake pedal gone rock hard urgent help needed
i know this is in wrong place place but i need help to sort this quick as i need car for work. tonight i jumped in my cossie started her up and red brake warning light stayed on had a quick look at fluid all was fine started to drive home brakes were perfect pulled up at a junction ok then set off again came to use brakes a minute later and the pedal has gone rock hard and the brakes hardly work any ideas please cos i rely on my car
try the pump on the brake master cylinder it has failed on mk3cosworths old escort 3 times it is sat close to the exhaust & turbo
it is the motor under the accumulator next to the fluid res it should buzz when the peddle is pressed if it isnt working the peddle is solid
is is also easy to change with the turbo heat shield removed
Jeebus
I had the same thing happen when I was driving once
I was driving through a housing estate down a hill after picking my mate up, fortunately it was early Sunday morning and no one was around. I went to brake and the pedal just locked and I had nothing! Had to use the handbrake to stop...
Turned out to be a green (or maybe it was purple) relay under the glovebox had gone duff!
Imagine if that had happened 5 mins later when I would have been doing 70+ on the motorway!
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
jessie_rs
11
03-06-2019 04:57 PM
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
