Vented disks - Brake dust
No, it makes no real difference if the disc is vented or solid - try a different pad compound.
Just in case you're considering buying cross drilled - don't do it. Slotted or dimpled is OK but drilled tend to crack under hard use - looking at the size of your discs I imagine they get quite hot so best to avaoid drilled discs.
I find my DS2500 dusting easy to clean, I once ran EBC Greenstuff and they didn't dust much at all.
(On-Ujah, do your DS's squeak???)
Charlie Chalk
you can buy rubber or plastic disks that fit behind the wheels ..but then you may have heat issues with the brakes...
if you dont drive flat out all the time they may solve your problem..
the new type out ATM
http://www.car-stuff.com/kwbrakedustshields.htm
JJ
JJ[/quote]
This might explain why they squeak like f...
Originally Posted by phill2400
Get wheels with stainless rims sooooooo much easier to keep clean. ![](https://passionford.com/forum/images/smilies/bling.gif)
![](https://img.photobucket.com/albums/1003/Mercury_Magic_S2/xbling.jpg)
No squeal here - they tend to squeal at first but after 500km it should go away - if not you need to take the pads out, clean everything and refit with copper/aluminium paste on the back and sides of the pad - basically anywhere it contacts the calliper.
As JJ kindly points out, i think i have glazed the surface and might need to lightly buff up the face of the pads on a level surface to deglaze them.
Resident Wrestling Legend
you make him sound like one of the bufty brigade
vented discs disipate more heat that solid ones, the brake dust issue is all down to the pad and it's use
if, like me, you only clean your car anually then you might have a problem (in the 9 years i've owned the estate i think i've only washed it twice
but i wash the mondeo every week at work
) but te main problem is going to be a uild up of brake dust, if you keep on top of it it won't be a problem, but when it starts to build up it tends to pit the alloys and lift the laquer off too
paint the wheels black,problem solved,or if like you said,you dont do looks over function,what the fuck are you worried about,just fucking leave it you bufty poof!
who gives a fuck if your wheels are dirty?i only get my car washed when the width of the car is actually wider from dust!
who gives a fuck if your wheels are dirty?i only get my car washed when the width of the car is actually wider from dust! ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Doing them matt black tomorrow anyway, providing the weather holds out
check this https://passionford.com/forum/viewtopic.php?t=262709
rsguy
44
29-09-2015 03:29 PM
