How do you eliminate boost drop ?
Depending how its set up,... any or all of the following could apply...
Turbo is running out of boost (consumed flow)
Actuator is weak.
AMAL valve is reducing boost (as would be reuired for stage 3)
AMAL valve is jetted to cause boost spike.
Actuator is weak.
No problem.
When I was "learning" about cossies,
I melted a stage 3 by turning the boost up a few PSI by removing
the AMAL valve and using a boost controller.
Just a little bit more....Just a little bit more....Just a little bit more....
BANG
BANG
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
