Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
30-03-2007, 12:05 PM
500bhp Cosworth in making
my car wont start after fitting wasted spark and closed loop to my ecu the coilpack is not actually bolted at min to bodywork does this need to be earthed or should it still start?
30-03-2007, 01:24 PM
30-03-2007, 01:29 PM
why dont u earth it and find out
30-03-2007, 01:40 PM
DO NOT TRY IT BLINDLY VERY BAD ADVICE FROM ABOVE
You do not need to earth the coil pack itself in any way.
30-03-2007, 01:43 PM
Middle wire ign.live, outer to to ECU (1 wire for 1&4 spark, other wire for 2&3 spark) - I think!!
Super Moderator
30-03-2007, 01:59 PM
well im stump whats up!!!
im using a coil from a fiesta rs turbo so im guessing it will be ok.
everyhting else is new
30-03-2007, 02:10 PM
and can i double check the pins do go in 21 & 26 of ecu?
30-03-2007, 02:14 PM
It's pins 25 & 26
Pin 21 is rev counter drive.
30-03-2007, 02:19 PM
no earth needed with a wasted spark system other than those created by the ECU
30-03-2007, 02:26 PM
USing the same system where would you pick up the rev counter wire from? (Ie - which pin on an eec iv ECU?
Chris
30-03-2007, 02:29 PM
Chris,
EEC4 works differently.
Roosie,
Have you read the instructions supplied ?
Quote:
Originally Posted by L8 ECU
It's pins 25 & 26
pin21 had nothing on it?
the wires i have on my coilpack loom have 21 and other has 26 taped on them.
heres inside of my ecu
30-03-2007, 02:31 PM
aint got instructions given to me have pm`d stu but obviously hes busy!
i got a wasted spark driver fitted and closel loop chip fitted at same time
got some instruction for closed loop but none for iaw system
30-03-2007, 02:32 PM
Pin 21 looks connected there to me
30-03-2007, 02:34 PM
Roosie,
Give Stu or Kenny a call directly PMs are for the website not his business.
30-03-2007, 02:35 PM
no i mean the connection that goes onto the ecu no 21 was empty but i put 1 of my wires in it and the other one which was 26 was also empty so put one in that also as numbered
30-03-2007, 02:39 PM
30-03-2007, 02:42 PM
i got the loom from ryan but i think there the same as stu`s so whats gone wrong
tried ringing stu but no answer
30-03-2007, 02:45 PM
cant scan the 10 steps fro me
30-03-2007, 02:53 PM
30-03-2007, 03:08 PM
30-03-2007, 03:12 PM
Quote:
Originally Posted by Roosie
What are the symtoms when you try and crank the engine over?
Describe exactly what happens.
30-03-2007, 03:19 PM
In your own time Roosie..............
30-03-2007, 03:21 PM
just turns and turns not a hint of trying to start!
when the ignition is on the fuel pressure regulator sounds like its just constantly leaking air
See how many signature colour changes you can get in Doug before he replies.
30-03-2007, 03:23 PM
Any tendency to back fire?
turns over fairly fast compared to normal
Is it not worth pulling a plug out to and turning over to see if you have spark?
JJ
30-03-2007, 03:24 PM
30-03-2007, 03:25 PM
its hard to check tbh as im on my own here and i have to crank it over and its a bright day and check but ill try in a bit
30-03-2007, 03:30 PM
Also, check that you havent disturbed the phase sensor when doing the conversion.
I presume that you have left the cap alone, but if you have removed it etc - this may explain it?
JJ
30-03-2007, 03:31 PM
Super Moderator
is the right hand side pin on that plug pushed in fully??? looks like the yellow insulating is sticking out a bit..
30-03-2007, 03:34 PM
Well spotted Eagle! Certainly looks a little suss!
30-03-2007, 03:41 PM
Quote:
Originally Posted by JjCoDeX75
Also, check that you havent disturbed the phase sensor when doing the conversion.JJ
Good point .............and Roosie - make sure the phase sensor connector (plug) is still in place (connected).
30-03-2007, 03:46 PM
ok
that was just a runner insert sticking out ehich i rectified earlier!
i didi take the dizzy cap off but the phases sensor plug is still connected ive put the dizzy cap back on without the rotor arm?
30-03-2007, 03:47 PM
If it has become unplugged, then you also need to ensure that it is re plugged in the correct way round - it will fit both way rounds! If it is plugged in the wrong way round then the engine wont start at all (much like your symptoms!)
JJ
30-03-2007, 04:05 PM
you forgot to take out the supressor in the green wire as mentioned
This can cause fatal damage to the coilpack driver
30-03-2007, 04:08 PM
UPDATE
when i put ignition on but not turn it the spark plugs spark like mad
constant then when u turn it over there is a weak spark
30-03-2007, 04:11 PM
is this the supressor with 2 green wires going to it? with a male and female bullet connector going to it
