Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
Old 12-04-2007, 09:15 PM
  #201
Roosie
500bhp Cosworth in making
Roosie's Avatar
Old 12-04-2007, 09:31 PM
  #202
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Originally Posted by the original
Stu @MSD, does the chip have pectel comms in it, I could try the IAW monitor...
Yes mate it does.
Old 12-04-2007, 09:32 PM
  #203
Originally Posted by Roosie
Did you try it then mate?
Old 12-04-2007, 09:46 PM
  #204
Roosie
Roosie's Avatar
yep no avail
is there anyone at APT RR day that will be running l8 and wasted spark i can bring my ecu to try it out
Old 13-04-2007, 06:43 AM
  #205
the original
the original's Avatar
I've put a monitor in the car to check it out when i can.
bit reluctant to try my ecu on the car when the ecu and amps are getting so hot
Old 13-04-2007, 07:38 AM
  #206
silky16v
Get on That!
silky16v's Avatar
did you by any chance unplug the connector for the crank sensor & the knock sensor and by accident got these the wrong way round?
cause i'd just done tis when putting my engine back together and has same issues as you fuel pump running all the time varied spark no injector cycle
swapped connectors back over and up it started oh the connectors are white
I'm running a L8 with Coil-pack and stage 3 setup
Old 13-04-2007, 02:48 PM
  #207
Roosie
Roosie's Avatar
cool mate just give me a bell when u want to pop round im in most time my number is 07876432430
  #208
Roosie
Roosie's Avatar
nah never took them off mate they still sit there pluged
Old 13-04-2007, 05:49 PM
  #209
heeman10
heeman10's Avatar
Definitely sounds like an odd, intermittent problem, which would make you think wiring or something like an ignition amp. Do I remember someone else saying their (perfectly functioning) car sparked the plugs when the ignition switch was only in position two as well? So that's not out of the ordinary? Can that person tell us if he gets the weak/strong/intermittent sparks that you're getting at switch position two (i.e. not position three, trying to start the engine)?
Have you tried different ignition amps yet?
Bloody nightmare, but it's great to see the effort everyone's putting in for you, good on you all!
Old 13-04-2007, 05:51 PM
  #210
heeman10
heeman10's Avatar
Roosie - As I sometimes ask people on fiestaturbo.com to do with bizarre issues like this, do you fancy taking some nice big clear pictures all around the engine bay? Show up potential error points, i.e. wiring, connectors and anything else. Gives people something to look at, and an obvious issue might jump out We're at that stage where anything's worth a shot hey?
You are definitely getting fuel aren't you? And do we know that when cranking the spark plugs are all firing okay now? Sorry, it's a long thread to remember all the details from with MSN convo's interrupting thought paths!
Old 13-04-2007, 05:53 PM
  #211
trevCOSS
trevCOSS's Avatar
[quote="heeman10"]Do I remember someone else saying their (perfectly functioning) car sparked the plugs when the ignition switch was only in position two as well?[quote]
yes mine does this and is otherwise fine
Old 13-04-2007, 05:56 PM
  #212
heeman10
heeman10's Avatar
Gotcha
Old 13-04-2007, 06:10 PM
  #213
cozmeister
More boost Igor!
cozmeister's Avatar
The ignition amps are good - we ran mine on them
Old 13-04-2007, 06:24 PM
  #214
the original
Roosie I rang you at 16:20 was gonna try the monitor but no answer
we will get it eventually
Old 13-04-2007, 06:26 PM
  #215
heeman10
heeman10's Avatar
Righty ho cozmeister, told you I was distracted when reading through this!
Old 13-04-2007, 06:28 PM
  #216
Roosie
Roosie's Avatar
yes loads of fuel mate!
there deffo no spark on turnover but an absoulute animal of spark on ignition i mean it will ark across 50mmm easerly and the coil hums slightly but this has been tested and ok.
im going to see what "the original" IAW moniter says and hopefully will tell me something
Old 13-04-2007, 06:36 PM
  #217
heeman10
heeman10's Avatar
Loads of fuel and 50mm sparks, great combo
I hope the monitor shows something up, get back on here with the results when you've done it
Old 13-04-2007, 07:36 PM
  #218
Roosie
Roosie's Avatar
sorry mate missed your call give me a ring again if you like cheers
Old 13-04-2007, 08:50 PM
  #219
I cant help but think there is an ECU issue here still, but the odds of you having 2 faulty ecu drivers is incredibly slim, as is teh chance we installed both badly.
Youve allready tried another chip, so that rules that out. I am almost out of ideas here mate.
What i may do is assemble another L8 Ecu with a driver and send it to you. I am not sure if we have a spare though, so will check tomorrow.
  #220
Daveesaunders
Daveesaunders's Avatar
Originally Posted by 2wd
Originally Posted by Daveesaunders
If your tacho reads as normal you wont need to fit the mod, I took my clocks apart and found they were different to the instructions so I put them back in the car without doing the mod and it is fine.
.. ok ..so did your tacho look like this ??
No, mine looked completly different to yours, I'll get some photos when I next take it out which should be soon as the lisght for the heater controls has packed in along with one of the ones on the clocks.
Old 13-04-2007, 09:19 PM
  #221
Roosie
Roosie's Avatar
Originally Posted by Stu @ M Developments
I cant help but think there is an ECU issue here still, but the odds of you having 2 faulty ecu drivers is incredibly slim, as is the chance we installed both badly.
i very much doubt i would have it done by apt rr day so ill have to run s1 instead
i suppose these dont get checked when they leave yours stu?
are you at APT on sunday?
Old 13-04-2007, 09:29 PM
  #222
i suppose these dont get checked when they leave yours Stu?
No mate, theres no way to check them, although Simon is actually sorting me out a simulation bench so i can do just that. We have sent out stacks of tehse things we have fitted and never had one not run. The chances of doing yours wrong twice is extremely remote mate, but of course not exactly impossible.
Cant you have teh car recovered here somehow?
Old 13-04-2007, 09:36 PM
  #223
Roosie
Roosie's Avatar
i would love to get car there but too far lol
there are no proper cossie specialist around here either
nah i very much doubt its something u have done but i may have blown something in ecu or something im oing to see when "the original" can stick is iaw moniter on and see if he can see anything
Old 14-04-2007, 07:36 AM
  #224
2wd
2wd's Avatar
hmmm...ok..I was hoping that yours where the same ...but please send some pic's when you get the time to do it..
Old 14-04-2007, 11:27 AM
  #225
silky16v
Get on That!
silky16v's Avatar
Just on the off chance rossie where about are you located?
As i have the same setup on my car and if you not a million miles away i might be able to help
Old 14-04-2007, 11:46 AM
  #226
The DIVA
The DIVA's Avatar
Matt.......
He`s about 305 miles away from you,and 216 miles from me........I had thought of popping over to help him out but it`s just a little bit far...
Old 14-04-2007, 11:56 AM
  #227
silky16v
Get on That!
silky16v's Avatar
Matt.......
oh ok shame as i could've put some miles on the old girl
Think i rang ya other day but you must still been in germany got problem sorted though you get saph fixed ok?
Old 14-04-2007, 04:53 PM
  #228
Roosie
Roosie's Avatar
everyone who has this conversion are all other side of country. im in east anglia!
Old 14-04-2007, 07:54 PM
  #229
Butch.
Butch.'s Avatar
mate where abouts are you? pm if you like if your anywhere near me i might have a look over it for you?
Old 14-04-2007, 08:30 PM
  #230
Roosie
Roosie's Avatar
thetford about 35mins from cambridge
Old 16-04-2007, 10:35 AM
  #231
Roosie
Roosie's Avatar
Updated!
had a fairly knowledgable cossie expert have a quick opinion today and he reckons its most likely a ecu fault
just need to find someone in the area with l8 closed loop to test
Old 16-04-2007, 11:05 AM
  #232
smartrs
smartrs's Avatar
nightmare
Old 16-04-2007, 07:19 PM
  #233
cozmeister
More boost Igor!
cozmeister's Avatar
If you'd have got a 2wd, you coulda borrowed my spare L6!!!
What did the IAW monitor say?
Old 16-04-2007, 07:28 PM
  #234
Roosie
Roosie's Avatar
ok rule ecu out again
The Original (stu) has been round with his spare l8 and guess what no difference
put a pectel moniter in and it dont show no faults found bar the water temp sender!
i think i got issues
Old 16-04-2007, 07:31 PM
  #235
L33 BYT
L33 BYT's Avatar
You haven't got an alarm/immob issue Stu have you?
Old 16-04-2007, 07:34 PM
  #236
Roosie
Roosie's Avatar
i have a toad ai606 mate cant see it being the problem tho
Old 16-04-2007, 07:51 PM
  #237
L33 BYT
L33 BYT's Avatar
Certainly a strange one mate! Hope you get it sorted soon.
Old 16-04-2007, 07:53 PM
  #238
Excellent, that means i can charge you for an hours labour installing a new driver.
Only joking pal, feel sad for you having all this trouble with her.
Why not try recounting your steps and listing EVERYTHING that happened to your car since the moment you removed the ecu and sent it to me. In fact, everything thats happened since you last had her running...
Old 16-04-2007, 08:06 PM
  #239
Roosie
Roosie's Avatar
i have thats the problem all i done was
change map sensor
change injectors
and take the old coil,leads off and fit new amp,coilpack and ecu
really buggered what i can do
ive just bought another l8 ecu which im going to stick my old coil and dizzt cap ect on and try it back the old way.
that should be here thursday
Old 16-04-2007, 08:09 PM
  #240
Roosie
Roosie's Avatar
Stu "the original" will explain the finding today
Quick Reply: Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
